Sub cone is getting hot
Username: Dustinv
Need some help please, i just bought a pretty simple setup compared to what ive seen and am having an issue..
I used 6 gauge power wire and ground wire, everything is pioneer, 12" sub is TS-W126M, and amp is GM-A5702. I set gain using a multimeter and the sub is bridged, i have my gains set at high and sub boost at, ive had the set up for about a week now but in the last couple hours my sub cone is hot and smells like its burning
Username: Tommyp
Man, that sounds bad. How much space is behind the subs? You should give it some room with air to cool down the equipment.
A friend of mine has the Pioneer TSSWX2502 which has a sealed enclosure and has no problem with heat.
Need to Register?
Forgot Password?
Enable HTML code in message
