Automotive LED lights
Username: Yx1991
Automotive LED lights, lighting and signal lights from the main action. Light emitted can illuminate the road ahead of the vehicle body, so that drivers can in the night safe driving, according to the current source can be divided into: a halogen lamp and a xenon lamp, but there are a few drawbacks: only halogen luminous flux 1300LM , the lights dim, the irradiation distance is relatively short, the impact of traffic safety. Although xenon lamp lights brighter, but start-up time in 3-8 seconds, overtaking, change light for too long, there are tens of meters dark area, affecting traffic safety. LED Lights,Car Accessories
Halogen and xenon lamp light low luminous efficiency, more power, longer battery life severely affected lights, power shortage can not even start the car. Originally halogen low brightness, color temperature xenon lamp more difficult to control, relatively low visibility in the rain and fog weather. Use of life in 400 hours, a xenon lamp 2000 hours in normal life are relatively short, the owner of the lamp must be replaced several times, the cost is relatively high. Xenon lamp voltage 23000V instantly prone vehicle circuit system disorders, severe and even burning cars, high-end cars more difficult to decode. DJI Drone,Phantom Series,Best quadcopter
Belong to heavy metals mercury, likely to cause environmental pollution. The EU now has legislation prohibiting the use of a halogen lamp and a xenon lamp, in 2018, all replaced with LED lights, high efficiency, energy saving automotive LED lighting systems, has been the state's key areas of concern, but also the Chinese people dream of several generations of cars, after three years of technical research , Guangzhou 9-plus-one finally made a breakthrough technology, developed automotive LED headlamps. Automotive LED main headlamps. {http://www.yitamotor.com,http://www.yitamotor.com}http://www.yitamotor.com/dji-drone.html
Need to Register?
Forgot Password?
Enable HTML code in message
