Help with two SA 10s plz and thx
Username: Laderface
So I currently own a 2009 avalanche and I'm wanting to add some bass to it. After reading forum after forum I'm pretty set on getting two SA 10s d2. Trying to find a premade sub box that fits the specs of the woofer. Came across one from car audio factory(1.32 cu feet per side,.268 cu feet for the port on each side) will this work ? I've also been trying to find a decent amp was thinking a mtx 1500 don't want to spend a crazy amount of money but around 600 bucks for a amp would be alright . If you could help me out and give me some suggestions that'd be great . Thank you
Username: Laderface
Any help would be much appreciated
Need to Register?
Forgot Password?
Enable HTML code in message
