Finding the right amp
Username: Dyllan_hanshaw
I am new to the whole modded sound systems and I had gotten a XOBP12D Dual Sub from a friend. It's says the RMS power handling is 600 watts and the Impedance is 4 Ohms. I was wondering if anybody had a cheap amp they could recommend to me to power this sub.
Username: Logan__tille
Indiana
Post Number: 9142
Well that's not a very good friend lol. I'm assuming it's a single 4ohm voice coil? If it works and you want to run it just pick up the cheapest amp you can find. Free would be ideal. It's really not worth spending money on. It would make a nice ash tray or paper weight though lol
Need to Register?
Forgot Password?
Enable HTML code in message
