Troubleshoot
Username: Bgladde13
Hey guys i have 2 brand new type r 10's dual 2 ohm subs. I have a legit alpine mrd 1000 amp, iwas wondering if that amp would push both of the subs?
Username: Joe1234
Post Number: 1970
Wire to 2 ohm and it will work, if you have the new 5th generation Rs you would be under powering.
Check your electrical system to be able to handle the power and set your gains right or something may get damaged.
