Pergeot 106 radio code
Username: Ten_thumbs
Hi,
A big thank you to the site, excellent all round.
I changed my wifes battery in her pergeot and now the radio is showing four bars, bingo!!. Not good.
Can you please supply a code for the following model,
PU-2294A
Serial number CL0401Y0119569
Thanks.
Username: Regrooster
Post Number: 11460
Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing.
(Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio.
