What gauge amp kit should I use for 120wrms
Diamond Member
Post Number: 23856
I'm gonna be installing a 2 channel amp for my truck. It is 120wrms @ 4ohms.
What gauge amp kit should I get?
Diamond Member
Post Number: 23857
BTW this is for a 8" shallow mount JBL sub.
Username: Mmaudioconcepts
KY USA
Post Number: 771
8
KY USA
Post Number: 772
but i know you already knew that lol
Username: Big_edge_head
Milwaukee, WI
Post Number: 4508
You'll need 00, Chad.
Username: Wolf_hound
Phoenix, AZ
Post Number: 1465
since its only 120rms an old lamp wire will do, but make sure u get one that has the turn on switch on the wire so it would work as a circuit breaker...
Diamond Member
Post Number: 23859
LOL. It's been awhile. I forgot.
Username: Rovin
1 15 = 153 DBs ...Trinidad & T...
Post Number: 17311
wow ur really out of it soo bad - lol
why not buy a 4 chan amp instead which will also power ur door speakers too
no not im not trying to sucker u back into car audio too much ...
Diamond Member
Post Number: 23860
LOL Rovin.
2 channel amp bridged is perfect. My factory door speakers actually sound pretty good with my new headunit. I'm just missing some bass. The bass from the speakers don't cut it. LOL.
I'll post pics of the setup and progress when the sub and amp gets here.
Diamond Member
Post Number: 23861
Btw I'm trying to use the thinnest cable possible. I'm tired of running thick cables though my door trims and etc......
I'm thinking a 10 or 12 gauge might even work. LOL.
KY USA
Post Number: 773
10 will work for sure
Username: Lord_huggington
Ontario Canada
Post Number: 600
You could throw a coat hanger wire on it and you won't know the difference.
Diamond Member
Post Number: 23862
LOL.
10 GA it is.
i'm gonna be doing something I haven't done in over 5-6 years. I'm gonna be building a small sealed box for the 8" sub I just bought. LOL. It's gonna be fun.
Username: Joe1234
Post Number: 1565
A shallow 8" on a small sealed box.... well hope you like it.
Diamond Member
Post Number: 23863
I hope so too Joe. I'm not going for big bass sound. I just want something small that is gonna fit under my rear seat of my truck.
