Eclipse 8712.4 subwoofer
Username: Aballman
I noticed there was a post on here about these sub's and i wasnt able to open any of the links for the info. Im looking for speaker box dimensions cant find anything its a 12 inch 8712.4 eclpise sub any help would be great.
Thanks
Username: Joe1234
Post Number: 1462
Eclipse 8712.4:
External diameter 12.38"
Cutout 10.94"
Mounting Depth 5.875"
Displacement 0.16 cubic feet.
No data on recommendations but with modelling software looks good on 1.9 cubic feet at 33Hz up to the rated 300W RMS power.
Username: Aballman
Thank you im looking at saving weight in my car i have 3 12 inch crossfire db's. I was thinking this speaker in the right box will have some punch and i can cut the weight. Whats better ported or sealed and is there info how much power it can handle sorry so many questions i will be using a crossfire 390m mono amp to power it.
Username: Joe1234
Post Number: 1463
I would go for a single 12" as you say but way more powerful.
Ported is better at getting the deeper notes loud.
That Eclipse is 300W rms.
Username: Insearchofbass
Post Number: 17204
An alpine type r would work very well for you even with your current power.
Username: Aballman
Thank You, Is there anyone that knows the ported box specs for this sub .
Username: Joe1234
Post Number: 1466
The Alpine? Sure 1.5-2 cubic feet tuned at 32Hz. If you want a cut sheet list for a box let me know.
Username: Aballman
Sorry not for the alpine for the eclipse 8712.4 ported box dimensions
Username: Joe1234
Post Number: 1467
As before I couldn't find a manufacturer recommendation for that older sub.
Through modelling 1.9 cubic feet at 33Hz up to the rated 300W RMS power seem adequate daily alignment IMO.
Username: Aballman
So that size is good for ported and sealed what size port would you suggest. I know its next to impossible to find any actual specs so i thanks you for your help.
Username: Joe1234
Post Number: 1468
0.8-1.0 cubic feet would be more than enough. Low EBP drivers work in sealed/4th.
