Quick wireing ?.
Username: Dloco486
Post Number: 220
To wire 2 dvc4ohm substo 1 ohm do i need to wire both subs together in paralell and connect to 1 terminal? Or can i wire each sub in paralell to their own terminals then wire the terminals on outside of box in paralell. Will I get the same outcome either way?
Username: Joe1234
Post Number: 1257
Yes you can wire the coils directly to each other BUT watching polarity positive to positive negative to negative and then to the amp, both subs. Monoblocks usually have separate terminals for each sub.
Username: Dloco486
Post Number: 221
yea i knew that about monoblock amps so if i wire each sub in paralell to their own seperate terminals and wire each terminal to their own channel on the amp it will be a 1ohm load correct?
Username: Joe1234
Post Number: 1258
That's right.
Username: Dloco486
Post Number: 222
Thank you. Thought so just wanted to make sure. Planned on hooking this one up on my own rather than pay 100$ for pro install.
