Replacing factory speakers
Username: Rosrock
Michigan
Post Number: 611
car malibu 2005. need 6 by 9's as well as 6 3/4's. Also there are 2 seperate tweeters located on the front, passenger side as well as drivers., so im not sure if I should replace those as well or just have nothing there? if so thatd be 6 total. powering with head unit deh-3400ub. budget 100 dollars. Not looking for anything amazing, just better than these paper cones lol. thx for reccomendations.
Username: Glasswolf
Columbia, South Carolina America
Post Number: 14638
Alpine type R 6x9s, and Alpine type R 6.75" coaxials in the front, or separates if you want the tweeters in the dash instead. your call.
I'd also recommend putting a 4 channel amp on these speakers for the best results in sound. it'll really bring them to life.
Username: Joe1234
Post Number: 1423
The above Alpines definitely are good options BUT more expensive, so here is something cheaper, I wouldn't go cheaper than this:
http://www.sonicelectronix.com/item_17730_JBL-GTO628.html
http://www.sonicelectronix.com/item_17736_JBL-GTO938.html
If you want me to recommend cheaper I will.
Username: Glasswolf
Post Number: 14646
yeah I forgot to mention the JBL speakers will be cheaper, but if yoou do want the Alpines, check Amazon or google shopping for the lowest price. you can find them well under MSRP with a little work.
Username: Rovin
1 15 = 153 DBs ...Trinidad & T...
Post Number: 17272
i like jbl speakers
check amazon or ebay for the lowest prices ...
Username: Rosrock
Michigan
Post Number: 616
i knew id get reccomended speakers higher than my stated budget.... figures. I must admit though... i pretty much raged when I saw wolfs first post. Im not looking for a total budget of $400 for type r's or $150 for the jbls . I stated $100.So obviously yes, I would want you to reccomend cheaper, otherwise I would have stated i wanted speakers within a $150 budget.
Username: Joe1234
Post Number: 1432
Ok then buy two pairs of these:
http://www.ebay.com/itm/JBL-GTO-628-6-1-2-2-Way-Car-Audio-Speaker-/150800320965? pt=Car_Speakers&hash=item231c6649c5
Username: Glasswolf
Post Number: 14655
if you want cheaper than Type R, go with Type S, or cheaper yet, Type E speakers.
Username: Rideredder
Cornell, IL USA
Post Number: 2041
Joe, did you realize that that listing is for one speaker only and not a pair? Also It's refurbished.
Username: Joe1234
Post Number: 1437
They are being sold by the manufacturer (harman audio) so I wouldn't care (and don't think it's one either but yes he'd need to ask). Anyways:
OP you can get them here also for $3.x each more:
http://www.amazon.com/JBL-GTO628-6-5-Inch-2-Way-Loudspeaker/dp/B003KN2TEY
You can also get one of these:
http://www.ebay.com/itm/New-Pair-Alpine-SPE-6000-2-Way-6-5-Car-Audio-Speakers-24 0-Watts-/300705563252?pt=Car_Speakers&hash=item460372c274
And one of these:
http://www.ebay.com/itm/ALPINE-SPE-6090-TYPE-E-6-X9-CAR-SPEAKER-CAR-AUDIO-SPEAKE R-2-WAY-COAXIAL-SPE6090-/110870183978?pt=Car_Speakers&hash=item19d060c02a
For $100.98 IF that's not too much to pay.
