Impedance and Wiring
Username: Jbam
I just have a quick question about impedance and wiring. Is there a site, or a post within this site that explains in detail how the impedance changes when wiring subs in series and parallel and how it changes based on the impedance rating of the sub? Im just confused.. I have the money to buy my first system now, but I don't want to end up buying the wrong thing. Thanks! JBam
Diamond Member
Www.stainles... .ecrater.com
Post Number: 25290
http://http://www.the12volt.com/caraudio/woofer_configurations.asp
Username: Jbam
Post Number: 7
that is a great help. Thank you sir.
Username: Jbam
Post Number: 8
So if I were to buy one 4ohm DVC speaker with the voice coils wired in parallel that gives me a 2 ohm load. (12" Alpine type R I am considering buying)
their site says 300-600 RMS is best for that speaker
So I want to look for an amp whose power rating at 2ohms is between 300-600 RMS x 1 channel, correct?
Username: Allthingsfresh
Post Number: 182
Correct, you want to buy a mono block amplifier.
Username: Joe1234
Post Number: 1153
Such as this:
http://www.sonicelectronix.com/item_33008_MB-Quart-FX1.600.html
Username: Jbam
Post Number: 9
Awesome. In your opinion, how does Alpine compare with MB-Quart?
Username: Joe1234
Post Number: 1154
Beware of the MRP-Mxxxx Alpine amps are prone to overheating, if you get some other series will be pretty comparable on SQ.
Username: Makinblak
Monroe/Monticello, La/Ar
Post Number: 795
A nd way more expensive
