AGU vs ANL fuse
Username: Noob101
Taylorsville, Utah USA
Post Number: 237
So i blew my fuse the other day and when going online to order a replacement i started reading about anl and agu fuses i currently have the agu fuse but they seem to blow rather frequently (say 1 every 2-4 months depending on drive time and volume). would you recommend i swith to an ANL fuse? if so what fuse rating should i go with?
It's going to be an in-line fuse the one about 6 inches away from the battery.
MY Setup:
Fi Q12 running off an ed nine.1 with 4 guage knukonceptz wire
Not sure if you need anymore information if so let me know. Thanks.
Also, of subject but whatever happened to this place? i remember like 3 or 4 years back when i first came here for help deciding on subs this part of the forum was very active with a lot of new threads and conversations everyday. anyway j/w
Username: Gcs8
Atlanta, Ga
Post Number: 2082
ANL 150A for OFC 100A for the CCA
Username: Noob101
Post Number: 238
Thanks. But, what is OFC and CCA?? sorry.
Username: Makinblak
Monroe/Monticello, La/Ar
Post Number: 727
Oxygen free copper.
copper clad aluminum.
Aluminum less dense blah blah
Username: Somedonniedude
Illinois Braaap MX
Post Number: 3219
what size agu fuses have you been running/blowing?
Username: Noob101
Post Number: 239
80A it's the ones that came with my amp wiring kit. why could that be bad?
And thank you i'll wait a few more days to see if theirs any new info someone here could add and then i'll buy the 100A CCA.
Username: Southernrebel
Post Number: 8521
I hate AGU fuse holders. The 'spring loaded' action of holding the AGU fuse inherently creates a bad connection.
I would HIGHLY recommend going to a mini ANL or ANL fused link.
I can't even begin to tell you how many cheap AGU fuse holders I have replaced in the last few years. I have seen them melt FAR TOO MANY times due to a bad connection within the fuse holder near the battery!!!!
The AGU fuse (from my experience in 12v audio) is the crap of the crappiest fused link. Hell, I would much rather see a MAXI fuse than an AGU.
I have also seen ALOT of AGU fuses 'blow' but 'not blow'....AKA, not totally sever the link to the batteries + terminal. AGU fuses tend to 'semi-blow'. They look fine in the middle of the fuse (don't look blown) but they actually separate from the endcaps of the tube. I have seen many AGU fuses mess up and still allow a limited amount of power to flow.
For instance. An alt/batt up front is setting at 14vDC, at the amp you are only seeing 9vDC. The AGU fuse is 'blown' yet still provides a high resistance connection to the amplifier!!!!
OP.
If you are running a nine.1...You need to fuse your (properly sized) power wire at 120-150A. A mini-ANL 150A fuse/fuseholder on true 4ga OFC copper power wire would be my choice.
Username: Tyronelutherkingjr
Memphis, TN USA
I never run fuses...fuses cause resistance and resistance mean power loss...I like keeping all my powers to my beats that way I never have fuse to blow out...if you wire stereo safe you don't need a fuse ...if you cut corners you need a fuse to keep your ride from melting to ground....
Username: Skies
Tofino, British Colu... Canada
Post Number: 953
^^ Words to live by.......
LOL
Diamond Member
Www.stainles... .ecrater.com
Post Number: 25161
Where the $#@! do these ppl come from?
Username: Joe1234
Post Number: 685
If anything just cannot go wrong, it will anyway.
Username: Thelonewolf
New Ipswich, NH USA
Post Number: 341
oh my... lol
Username: Dcollister440
Post Number: 59
dude, that dude is crazy....NEWS FLASH MAN DIES IN CAR AUDIO FIRE!!!!
Username: Loc_out
SoCal
Post Number: 3312
"I never run fuses...fuses cause resistance and resistance mean power loss...I like keeping all my powers to my beats that way I never have fuse to blow out...if you wire stereo safe you don't need a fuse ...if you cut corners you need a fuse to keep your ride from melting to ground"
I like this guy, how much power are you running?
Username: Mash4kash
Lafayette, LA
Post Number: 351
I run a circuit breaker they're only $10. So if it trips you just flip the switch.
Username: Insearchofbass
Post Number: 17183
fusing should be a set it and forget it. You should not be blowing fuses constantly. Someone isnt doing something right.
