Help choosing amp for my single 12" Alpine Type R
Username: Its_budddah
SB, CA US
hi everyone, I Need help choosing a better amp for my alpine type R. I have the model one before the newest ones. It's 500 watts RMS and 1500 peak. I currently have it hooked up to a performance Teknique 1200 watts. I'm going to buy a new amp but I need advice on which one to buy? My budget is $250 and ofcourse the amp will be used (from local craiglist) I've seen Alpine AMP mrp-m500,jl 500.1 and some hifonics. I really don want to go TOO high in watts because I don't want to blow the sub. I will really appreciate if you guys help me get the best DEEPEST bass out of this subwoofer.
Thank you all
Username: Joe1234
Post Number: 273
For deep bass you can also look at rockford fosgate monoblocks, but those two you mention will also get you good results.
Username: John253a
Post Number: 45
what ohm sub and is it a dual
SB, CA US
How do i find out about the ohms configuration?
Username: Joe1234
Post Number: 276
Alpine SWR-1222D is dual 2 ohm coils.
Alpine SWR-1242D is dual 4 ohm coils.
Both are 500W RMS
Username: Makinblak
Monroe/Monticello, La/Ar
Post Number: 670
Go to db-r.com and check out the refurb sundown amps. U can't beat em
SB, CA US
Hey john253a i found out its a 4 ohm
Username: Joe1234
Post Number: 282
Its_budddah, is this the model number?
Alpine SWR-1242D
SB, CA US
yes it is that model, here is some pics of how i have it hooked up, and i currently have it with a cheap performance teknique icbm 779 <img>
Username: Joe1234
Post Number: 320
If you want a 500W RMS at 2 ohm amp with strong bass check this:
Rockford Fosgate PRIME R500-1
http://www.sonicelectronix.com/item_17368_Rockford-Fosgate-PRIME-R500-1.html
Just wire your subwoofer coils in parallel and you are done.
SB, CA US
thank you!
SB, CA US
anyone know how to fix this from one of my subs?
<img>
<img>
the sub still works if i put pressure against the cone
what kind of glue>?
Username: Joe1234
Post Number: 329
I guess that performance Teknique wasn't that bad after all
I don't recommend fixing that yourself, many times the glue ends up in the wrong place.
