Radio code for Nissan Primastar
Username: Amd1981
Raunds, Select United Kingdom
Hope some one can help. I need a radio code for a nissan primastar
These are the numbers off the radio:
T7202
RNRDAW70280145
FDO507400280145
8200633634T
Thank you ,
Username: Regrooster
Post Number: 8216
T7202 please check this again
We require the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode
If in doubt post ALL the letters+numbers on any labels or barcodes
Username: Amd1981
Sorry, T702 - I think this is the security number.
Thank you.
Post Number: 8219
try code 6239
Username: Amd1981
Thank you - it worked
