What makes a high quality subwoofer
Username: Zinna722
Super slim subwoofer
1. slim----can save a lot space ,
2.cable controled--- convenient
3good sound quality
4. All aluminum metal housings --good for heat radiation
5. Wight: 6KG-- shockproof
Easy to install
Reference: 12vcity
Username: Joe1234
Post Number: 269
No link yet??
Username: Makinblak
Monroe/Monticello, La/Ar
Post Number: 669
Spam has waaay too much sodium in it to preserve freshness and kill u and me
Username: Glasswolf
Columbia, South Carolina
Post Number: 14495
not really an advantage to performance. only a plus if space is extremely limited.
convenient for whom?
>3good sound quality
says whom? and on what scale? no mention at all of motor architecture, basket rigidity, Bl curve, or anything that actually matters.
umm, sure, if you're welding the sub basket to the sub box, I suppose.
Doesn't make a bit of difference to the sub, since the heat generated by the voice coins and motor are cooled by proper motor design and pole venting, coil winding wire type, and so forth.
that I'll buy. I'm not shocked at all. 12lbs is feather weight in the world of subs. Now I know why there's no Bl curve listed.
>Easy to install
again, for whom? every sub is easy to install. drop it in the hole and screw it down. The hard part is designing and building the BOX is goes INTO.
This entire thread is completely useless.
Username: Makinblak
Post Number: 676
Go to a thread where there r idiots for u to share ur koolaid with cuz we ainnt havin it
