2002 Ford Windstar Radio Reset
Username: Musicmom
We removed our radio to fix a heater problem in the dash and now can't get the radio to work correctly. If anyone has a suggestion or knows how to reset the Windstar radios, your help will be greatly appreciated!!
Username: Regrooster
Post Number: 8033
The radio SERIAL NUMBER is required for a code
First remove the radio from the dashboard.
Then post the radio make+model plus all the letters+numbers on any labels,barcodes or stamped in the metal casing.
This information can then be used to see if a code can be calculated
