200 WRMS 12
Username: Dloco486
Post Number: 117
is there a better 200 watt sub for sq than a jl audio wx?
Username: Lord_huggington
Ontario Canada
Post Number: 414
No. Nothing beats JL in anything, except maybe any other driver. Look at the SSA DCON.
Username: Somedonniedude
Illinois Braaap MX
Post Number: 3191
Ascendant audio assassin should work well.
http://ascendantaudio.com/assasin.php
Username: Jbpitt
Pittsburgh, Pa. Usa
Post Number: 1260
https://ssl.perfora.net/www.ficaraudio.com/sess/utn;jsessionid=154e2f1aa3aac03/s hopdata/0050_Speakers/0045_X/product_overview.shopscript
Username: Joebruce
Crescendo Audio FTMFW!!!, AA Havoc 15 ... Your Mom FTW!!!
Post Number: 3598
Ascendant Audio FTW!!!
AA > JL
Username: Dloco486
Post Number: 127
not tryin to sound too behind but wut does ftw mean?
Username: Dloco486
Post Number: 128
i'm lookin for a sub that is single 4 ohm or dvc 2 ohm and that fi i can only push half the power it needs. i have a rf 2002 amp. it says 200 watts bridged at 4 ohms. for my wifes car. so im only lookin for sq she dont like loud hard hitting bass just wants something that sounds nice. the aa and dcon both were dvc 4 ohm so won't work. well they will but amp won't last long lol.
Username: Joebruce
Post Number: 3615
FTW means for the win.
This will be perfect for what you're looking for
http://cgi.ebay.com/DIAMOND-AUDIO-D112D2-2-12-D1-Car-Audio-Subwoofer-DVC-/390240 275937?pt=Car_Subwoofers_Enclosures&hash=item5adc220de1
Username: Dloco486
Post Number: 135
thanx twiztid i was thinkin about getting one of those d1's a while back and someone told the d1's werent real great but it was somebody who doesnt know a whole lot only looks for real loud bass. i knew the d3's were pretty good though heard a set of them before. the d1 is better than the wx for sure?
Username: Alonzoub
Post Number: 238
The SSA DCON comes in a single 4-ohm coil or Dual 4-ohm coils... check it out: http://www.soundsolutionsaudio.com/store/products/12%22-SSA-DCON-12D4%7B47%7DS4. html next to Voice Coil Options just click the "Single 4-ohm Coils" option.
Username: Dloco486
Post Number: 137
thats cool but every time i click on an option it says combination currently unavaliable. will the dcon sound better than the d1 gettin 200wrms?
Username: Alonzoub
Post Number: 240
Ive never heard a D1 so I cant comment on that, but I guess the DCONs might be temporarily out of stock? Personally I would call them to get the inside scoop on whats goin on with the DCONs before making any decision.
Username: Denim
SSAudio.com, MD USA
Post Number: 930
The SSA Dcon 12's are out of stock for a few more days as we are waiting on cones to come in.
Username: Joebruce
Post Number: 3619
Ya know what I completely forgot about the AQ SD2.0! The RMS is 250 and the 12" is on sale right now for $79! I would grab the AQ and be done with it.
Username: Dloco486
Post Number: 144
it says d4 is it dvc 4 ohm cuz if it is i think it'll kill my amp but that sounds like a good deal if it wont kill my amp ill definitely pick that one up
Username: Joebruce
Post Number: 3621
Oh yea I forgot you needed a 4ohm load. Im pretty sure the SD2.0 is in fact dual 4ohm. Damn that sub would have been perfect. Hmm do you absolutley have to use that amp? Are you just trying to use what you already have so you dont have to spend money on a new amp?
If you dont think the Diamond D1 will be loud enough or sound good,how about a Diamond D3? The RMS is 400 but it will get loud enough on 200wrms. That RF amp may be a little underrated too.
http://cgi.ebay.com/DIAMOND-AUDIO-D312D2-2-12-D2-Car-Audio-Subwoofer-DVC-/350455 527534?pt=Car_Subwoofers_Enclosures&hash=item5198c6f86e
Or how about a Dayton Audio woofer?
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=295-204
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=295-185
Username: Dloco486
Post Number: 147
ive heard the d3's and they sound great. i dont really want to use a bigger amp cuz my wife dont like her music real loud. i just want it too sound nice. i was thinkin getting her a d1 a while back and forgot about it when i posted that wx. this is going to go in the trunk of a 94 cutlass ciera. i wish u could get those aq's in dual 2 or single 4. but i would like to match it to the amp if possible. if u know of 2 8's that would sound good 2gether and create a final 4 ohm load i'm up for suggestions on those too. but i dont want to spend more than 120$. i'm trying to use minimal space.
Username: Dloco486
Post Number: 149
in this set up would i be better going with 2 8's rather than 1 12 for sq. if so can any body name some good ones for me that i can use to create a final 4 ohm load and doesnt go to high over 200 watts rms. i am lookin to spend no more than 120$
Username: Southernrebel
Post Number: 8508
Arc Audio KS12.
Just throwing another option out there.
Username: Dloco486
Post Number: 152
that one looks like a very nice sub but a little more than im wantin to spend but i will keep it in consideration though thanx
Username: Joebruce
Post Number: 3623
Just pick a damn sub and buy it already!!!! lol I know it can be a tough decision.
Username: Dloco486
Post Number: 155
lmao! is 1 12 better than 2 8's for sq?
Username: Joebruce
Post Number: 3625
I would rather have 1 12"
Username: Dloco486
Post Number: 156
thanx ill probly go with 1 d1 12 then my wife listens to soft rock and country and some classic rock so do u think i should seal it and if so wut size box should i go?
Username: Joebruce
Post Number: 3626
Yea I would go sealed for sure. As far as box specs,Im not sure. It should list the specs in the description of the sub. A well built prefab would work just fine. Just make sure it is made with at least 3/4 MDF and not some thin plywood or somethin.
Username: Dloco486
Post Number: 168
1 more question on this thread. is that d1 better than the alpine swe 1243?
Username: Alonzoub
Post Number: 244
Yes
Username: Dloco486
Post Number: 176
thanx the d1 was the sub i was thinkin about when i bought the amp from my buddy a few mnths ago i just completely 4got about it.
