Amp isn't installed yet, my dealer is out of 1/0 gauge at the moment, just need to run it to my back battery to help with charging as theres only a 10 gauge wire there right now. So I've got it running of my 5 channel temporarily.
What size wire would you run from battery to amp for ~1200w? I need to order distro block but not sure what I can get away with.
With zero ga. he can run up to 2500 watts using a class d amp. Most people arent going to run more than that and if he does he just has to add a second run of zero ga. that was my point.
i agree zero gauge is best suited no need to push it to the limits with the 4. Nice install by the way looks sweet. what are you running for mids and highs?
Mids and highs are just infinity reference coaxials right now running on 50w. It's on the list to be upgraded <span class="ib sp happy"></span> Probably gonna look into the new crescendo audio components.
According to the link below, I'm borderline 2/4 gauge, I'll just use 2 gauge if I can find some, it's only about 5 ft.
Looks clean. Just wondering.....why did u put the box behind your seat? I would put it behind passenger to retain full reclining priviledges. Sounds a lil dif, too.....which is prolly ur reason.
