Will my stereo sound good?
Username: Skillz215
Ok so I just bought 2 12" (1000 watts each) sony xplod subs already in a box, a 1000 watt kenwood amp and a kenwood deck for $350. I just wanted to know if it will sound good? or should i sell it and try to find something else
Username: Nd4spd18
Philadelphia, PA
Post Number: 11930
no. get something else
Username: Joe1234
Post Number: 374
I don't know what do you mean by good, and what will you use for speakers.
Anyways the subs are junk, the Kenwood stuff is ok unless you are looking for top gear.
I you list the models I may come up with some extra info.
Username: Kaerfpl
Spencerport, NY USA
Post Number: 1356
Any system can sound "good" regardless if it's crap or gold. Everything all comes down to the install.
Are you looking for a SQ or SPL System?
