New member Username: SpcbaileybPost Number: 1 Registered: May-11 | i have 2 KENWOOD W3012 12 Performance Series Subwoofers in a crappy tiny sealed box running on a kicker 750.1 zx amp they are 1200 watt peak, 400 rms, in parallel so at 2 ohms.My car is a 93 Jeep cherokee sport. I want to know, 1. Should my seats be up or down in the back or does it make a difference, what is the ideal placement of the box and which direction should it face? I want to buy plexi glass and have a professional create a box for me. Should it be sealed or Ported or a bandstand? *** that's my most important question there. I want it to hit HARD but not sound bad either. i'm kinda tone def so it dont hae to sound perect XD but good enough that I cant tell! |
Gold Member Username: Gcs8Atlanta, Ga Post Number: 2047 Registered: Sep-09 | as far as seats and box placement play around with it until it sounds good to you, as far as box building goes, >>>>> http://www.dldesignz.com/ |
Gold Member Username: Dustin3Box Designer & Builder...Dustin Post Number: 5914 Registered: Oct-05 | Thank you sir |
New member Username: SpcbaileybPost Number: 3 Registered: May-11 | wow thank you |
Silver Member Username: Nevertoomuchbass2 Fi Q 12s, Mmats 3000.1 Post Number: 269 Registered: Aug-10 | seats up or down wont matter. id think something like 3.5-4 cubes tuned to maybe 38hz would sound good. in theory, they would sound the best if you had them rear facing really close to the rear hatch, but it wont really sound too different if you just face them rear and push em up against the back seats. or maybe even try facing them up. But dustin does great work so im sure youll be more than satisfied with whatever he does for you |
Gold Member Username: JbpittPittsburgh, Pa. Usa Post Number: 1204 Registered: Jul-09 | I know in my car the seats down make a huge difference in sound,but every cars different i guess. Tell bassman what you want,he'll hook a brotha up... |
Silver Member Username: Armykyle1Ms Us Post Number: 962 Registered: Dec-08 | moving the subs closer to the rear typically makes it peak higher. I've noticed moving them further from the rear gives a deeper cleaner sound. IMO |
Silver Member Username: Lord_huggingtonOntario Canada Post Number: 402 Registered: Oct-10 | You jumped the gun. Plexi-glass is expensive and isn't going to do much on that little power & cone area, you're asking if you should get a sealed box and then ask about plexi glass - get real. Bandstand, lol... that's hilarious. |
Silver Member Username: MakinblakMonroe/Monticello, La/Ar Post Number: 630 Registered: Oct-10 | Don't be mean |
Silver Member Username: Nevertoomuchbass2 Fi Q 12s, Mmats 3000.1 Post Number: 272 Registered: Aug-10 | Art what kind if car do you have? because i know it makes a pretty good difference in cars, but in suv's, i havent been able to tell any difference |
Gold Member Username: JbpittPittsburgh, Pa. Usa Post Number: 1207 Registered: Jul-09 | Nissan Murano. Depending on where i place the box,it makes quite a difference in sound. Why? I have no clue... |
