Looking for an amp
Username: Deadrabit
Marionville, MO
Post Number: 2620
hey every one. i hate to post topics like this. but i know u all keep ur eyes out for good deals.
i am looking for something that puts out 500 watts at 4ohms or 1 ohm.
i have a pair of dual 2 ohm woofers. just looking for a cheap amp for them! thanks all
Username: Alonzoub
Post Number: 126
A pair of D2's? So wouldn't you need it to put out power @ 2-ohms?
Or you powering each sub off its own amp?
Username: Kaerfpl
Spencerport, NY USA
Post Number: 936
If you were looking to power two DVC 2Ohm subwoofers with one amplifier, you will need to have it wired up as one of the following below:
Parallel: 0.5Ohm Load
Series/Parallel: 2Ohm Load
Series: 8Ohm Load
With that said, if you are looking to have an overall total of 500Watts RMS at one of the Loads above, then I would suggest looking into one of the listed amplifiers below:
Audioque AQ750 ran in the Series/Parallel to create a 2Ohm Load
http://www.audioque.com/AQ750-Amplifier_p_46.html
Kicker ZX500.1 ran in Series/Parallel to create a 2Ohm Load
http://www.sonicelectronix.com/item_21955_Kicker-ZX500.1-10ZX500.1.html
Alpine MRP-M500 ran in Series/Parallel to create a 2Ohm Load
http://www.sonicelectronix.com/item_12018_Alpine-MRP-M500.html
These are just a few amplifiers that I can hunt down at this time that are a reasonable price.
Username: Deadrabit
Marionville, MO
Post Number: 2621
oo sorry guys. 2 ohms is more what i am looking for .
those are not good deals....
Username: Kaerfpl
Spencerport, NY USA
Post Number: 948
Even so, if your looking for a 2 Ohm Load, that Audioque Amplfier posted above will make you real happy.
Keep in mind, that you get what you pay for. Lower quality products will not last as long and may not be rated correctly. For $200, that's a steal.
Username: Deadrabit
Marionville, MO
Post Number: 2622
no joe.. i dont' want a 2 channel
Username: Rovin
1 15 = 153 DBs ...Trinidad & T...
Post Number: 16988
some companies like kicker , jbl , mtx , jl usually make 2ohm stable amps ...
Username: Nd4spd18
Philadelphia, PA
Post Number: 11882
" Keep in mind, that you get what you pay for. Lower quality products will not last as long and may not be rated correctly. "
This.
" no joe.. i dont' want a 2 channel "
WTF are you talking about... those amps are all mono...
For the record I second the AQ.
