18" subs and amps?
Username: Austin201195
Post Number: 11
I want to get 2 18" subs and an amp to power it all. What is a good brand for subs and an amp for that?
Username: Lord_huggington
Ontario Canada
Post Number: 381
Vehicle?
Space?
Budget?
Listening to?
Post Number: 12
Car
Not too much space
Budget as much as I want to spend
Listening to rap so I need sonething that thumps
Ontario Canada
Post Number: 383
... than use any 18's in any space on any amp with anything else, do whatever you want.
You're so vague in all of your posts that we can't help you, it's irritating that not only do you not give us specifics, you don't even know what questions to ask. If you were ready for 2 18's than you'd be able to answer your own questions.
I'm finding it hard to believe you'll do 2 18's, or even own a vehicle.
Username: Cwruck
Post Number: 572
2 18s in a car is going to mean a wall in the back seat.
I figure since you said you listen to hip hop and want to bump go for some 12s.
But your best off just going to a higher end car audio shop because with the info you gave. It will be a project you couldn't handle on your own
Post Number: 13
It would be in a Nissan sentra but I know how to wire it all on and everything so I don't need to take it to a shop
Username: Cwruck
Post Number: 576
Then do a wall with some digital designs 9518s and use a digital designs m4a as your amp.
That would be a loud system
Username: Skdooley
Roanoke, VA Usa
Post Number: 1563
You won't have the room for a proper enclosure for 18s. Do a couple twelves or a single 15, ported low in as large of an enclosure you have room for. Should satisfy you.
Username: Makinblak
Monroe/Monticello, La/Ar
Post Number: 602
Making noise is one thing. We can all do that by touching some wires to some other things. There is much more to think about here, in order to get the most bass with ur space. 2 18s will not fit. Its that simple. They technically could but u would b choking them ssoooo bad that 10s with a proper install could beat them 18s up. Go 2 12s or 115 U mite could even do 1 18........ but remember.. ur box = 75 % of the bass u make. Pairing the right sub to the right box = 10%. Amp, power supply, HU, and myriad other factors beyond ur comprehension = the final 15%. Be specific with ur ?s annd we will guide u grsshoppa
Post Number: 14
Thanks everybody. What about a jack hammer though?
Username: Makinblak
Post Number: 603
mwahahaha how about the troll 9,ooo or even the troll-bot 11,000 !!!
Username: Rovin
1 15 = 153 DBs ...Trinidad & T...
Post Number: 16980
get some funky pops - best subs ever made ! .....
Diamond Member
Www.stainles... .ecrater.com
Post Number: 24686
Jackhammer?
I suppose you didn't take into consideration the dynamic pressure you'll exert on the polar axis of the motor structure? Sub-dividing the linear phase will be a MUST. If the ohms of the output signal aren't balanced with the crossover ratio then you'll be in big trouble. The Jackhammer was designed and intended for extreme bass with possible pressure recordings in upwards of 185 DBs!!!
Throw in an oscillation transverse multiplier and you could add 5 DBs to that number. Buddy of mine has one and he blew out the windshield of his neighbor's car! There are rumors that even basketball backboards have been victimized by this insane beast.
Think of the babes you'll get.
Username: Jbpitt
Pittsburgh, Pa. Usa
Post Number: 1189
lol
Username: Rovin
Post Number: 16981
paul = ...
Username: Insearchofbass
Post Number: 17094
lol
Username: Makinblak
Post Number: 604
X2 hahaha
