Small vid/questions
Username: Jbpitt
Pittsburgh, Pa. Usa
Post Number: 1162
I oringinally had this Q in my neon,but i decided to put it in my other car and put the epics i had in the neon. Anyways,quite a huge difference in sound from the trunk car to this one. Its ALOT louder and cleaner sounding even with just a loc. At some point though,i would like to find someone to put an aftermarket hu in there. The shops around here are just idiots so that might be pretty difficult. The box in the vid was givin to me by my brother. He was running a 15'' bl in it,it is a pre-fab(yes i know) but i gotta say for a pre-fab its built quite well and sounds pretty good.
http://www.mobilesoundworks.com/ProductDetails.asp?ProductCode=4%5F0%2Dmsw%2D115
Anyway,its just till i can get one built. The other box i have is just a tad to long.
http://www.youtube.com/watch?v=S622LXvQJNI
Ok, a couple questions.... When setting the amp with a dmm is there a different way that it needs to be done when using a loc? Im kind of limited with settings on the factory radio. What else could i buy to boost/improve the sound?
Username: Skies
Tofino, British Colu... Canada
Post Number: 922
Nope.
Same as if you had just installed a new aftermarket HU.
http://www.astrosafari.com/viewtopic.php?f=32&t=517
^^ Good tutorial for setting the gain.
I guess if you can't reach your target voltage you would need to boost the signal somehow, although I'm not exactly sure how you do it. Maybe someone else here would.
Cheers,
Username: Joebruce
Post Number: 3383
http://www.sonicelectronix.com/item_5349_JL-Audio-CL441dsp-CleanSweep.html
http://www.woofersetc.com/p-4981-3sixty1-rockford-fosgate-interactive-signal-pro cessor.aspx
http://www.woofersetc.com/p-4982-3sixty2-rockford-fosgate-interactive-signal-pro cessor.aspx
Username: Makinblak
Monroe/Monticello, La/Ar
Post Number: 548
don't mean to hijack the thread, but.......
What is the voltage coming from a 3.5 mm headphone jack that i plug into my rca input on amp?
Username: Jbpitt
Pittsburgh, Pa. Usa
Post Number: 1164
Do they make a signal processor to where i can just come from the loc i already have in there,and just go to the processor with my rca plugs? Or am i just better off taking out the loc an buying something like that? The radio/dashboard is a b itch to get apart and very little space to work with,thats why im asking.... thanks again
Username: Jbpitt
Pittsburgh, Pa. Usa
Post Number: 1165
Anybody?
Username: Nd4spd18
Philadelphia, PA
Post Number: 11814
Tell me what make model and year vehicle, and which stock system it has if there are options, and I'll show you what you need.
OEM integration has sort of become one of my specialties... with the stock radios becoming so advanced in new cars, it's what everyone's wanting these days.
Username: Skdooley
Roanoke, VA Usa
Post Number: 1551
That Q sounds clean in the video.
Username: Jbpitt
Pittsburgh, Pa. Usa
Post Number: 1169
I appreciate it ms. 06 Nissan Murano S, w/o bose system. Yea it sounds pretty good with just the loc,but somethings missing i just cant put my finger on it.
Username: Jbpitt
Pittsburgh, Pa. Usa
Post Number: 1170
This is the loc i currently have installed
http://www.pac-audio.com/productDetails.aspx?ProductId=175&CategoryID=28
Username: Drant19
TX
Post Number: 2230
I have an 2007 Avalanche and i used the AudioControl LC6 and it works great with my stock Bose HeadUnit
http://www.audiocontrol.com/31215/products/LC6-Six-Channel-Line-Output-Converter .html
Just an option
Username: Nd4spd18
Philadelphia, PA
Post Number: 11820
Ok in that vehicle there is no way to get low-level signal out of the stock HU, so you're stuck with a LOC of some sort, but some are much better than others.
I'm about 90% sure a PAC AOEM-NIS2 will work even tho they don't list that specific vehicle. What that is, a LOC that plugs in-line to the radio harness and gives you 4ch RCA out. PAC audio products are about the best out there so if you are absolutely stuck with using an LOC they are the way to go.
Username: Nd4spd18
Philadelphia, PA
Post Number: 11821
That LOC you already have is actually not bad. If it still sounds like somethings missing, it's very likely the only solution is going to be an aftermarket HU. Even with the best equipment the signal is only as good as the source unit, which can range from not bad to terrible.
Username: Insearchofbass
Post Number: 17041
Username: Jbpitt
Pittsburgh, Pa. Usa
Post Number: 1171
I would love to put an aftermarket hu in there,but its a custom job that i dont have the skill or patience for. Have a look...
http://www.nissanmurano.org/forums/74-nav-gps/14745-aftermarket-stereo-murano.ht ml
To somebody that knows what there doing im sure its not to difficult
That PAC AOEM-NIS2 just plugs in between the harnesses?
If i did go with something like that LC6 would i go from the loc to that or does that just replace the loc altogether?
Username: Nd4spd18
Philadelphia, PA
Post Number: 11826
Yikes. That is one of those P.I.T.A. cars where you can't put an aftermarket HU in there without major custom work. LOC is probably your only option there. Only good thing is newer stock units are a lot better than they used to be so it's possible to get fairly good results.
And yes that PAC adapter would just plug in-line to the radio... although I'd recommend calling PAC first to verify compatibility... after seeing those pics I'm starting to doubt whether it really would work or not.
Username: Jbpitt
Pittsburgh, Pa. Usa
Post Number: 1172
I dont understand why they make these stock radios like this. I mean i do,but it just pisses me off. lol I guess i could always do something like this
http://www.nissanmurano.org/forums/69-audio-electronics/15912-installed-aftermar ket-radio-my-2006-murano-pics-inside.html
Im thinking of maybe trying something like the LC6 out. Is it really going to make that much of a difference tho? I mean is it going to be worth trying?
Username: Nd4spd18
Philadelphia, PA
Post Number: 11832
No. The PAC audio LOC you already have will give you about as good results are you're going to get. You can do all the EQ/processing you want, output will only ever be as good as the input.
Username: Jbpitt
Pittsburgh, Pa. Usa
Post Number: 1175
Ok gottcha,i appreciate the help man.
Username: Nd4spd18
Philadelphia, PA
Post Number: 11852
no problem, gl with it
