Ssealed box size for TODAYs build
Username: Makinblak
Monroe/Monticello, La/Ar
Post Number: 560
Im building a sealed box for 1 L7. 12" kicker recommends between. 88-2.0 cubic feet. What differences would I experiece between both extremes of this range?
Username: Somedonniedude
Illinois Braaap MX
Post Number: 3158
frequency response change, small box more output on upper bass notes, big box more output on the low end.
Username: Lord_huggington
Ontario Canada
Post Number: 331
You can model the response yourself with the T/S, which is at the bottom of Kickers' main site in a .PDF.
Shoot between a QTC of .5 and .707, .5 for lows, .707 for flatness.
http://www.carstereo.com/help/Articles.cfm?id=30
Illinois Braaap MX
Post Number: 3159
Slackin, you should get yourself setup with a sealed box and some polyfill. play around with adding/subtracting it to/from the box and hear the difference for yourself.
Username: Makinblak
Post Number: 561
I figured iit was sumtin like that. I would mess around w it, but I sold the sub and box.
