Renault megane dynamique radio code
Username: Buluqu
Hi can any one help me find my radio code for Renault Megane dynamique saloon 2005 model chassis number VF1LMSE0634746762
Username: Hay88
PortsmouthUk
Post Number: 3312
you need to remove the radio.
they are too small holes each side of the radio
use an old metal coat hanger 4 darts or very small screwdriver or long nails.
put into holes about 4-5cms and push outwards sideways
and carefully pull radio forward.
you must do the holes on each side at the same time
Then post the numbers/letters from below the main barcode
something like 7700xxxxxxtt123 or 8200xxxxtt123 or
the security code like Q123 or T0U123
can be found in a small box then i can help you
Username: Buluqu
my radio is carminat with cd changer and doesnt have holes like normal radios i dont know how to remove it can you tell me how pls
Username: Regrooster
Post Number: 6136
have a look through here
www.fitaudio.com/index.php?CategoryID=10
Username: Buluqu
mine is different from the one that they show on the site you gave me cause mine is Carminat navigation system with 6 cd changer can you help me whit this thank u
