93 acura integra radio code. help please!!
Username: Dandyke1234
my battery got disconected and now i need a code. i looked up what i needed to do to get the code and it said i had to get the serial number off the radio and give it to the dealer. the problem is that the dealer wants to charge me $50 bucks just to llok up the code... please help
the serial code is
MK 26363
send me a msg with what you find
thank you.
Username: Regrooster
Post Number: 6128
If you can provide the necessary information then your ACURA code is available here for free
https://radio-navicode.acura.com/?src=inq
If not then the code will only be available from your local Honda Dealer or a Decoding Service ...who will plug in a laptop to read/recode your memory chip (EEPROM)
thank you
