Need help again
Username: Basshead94
Centralia, Illinois United States
Post Number: 26
i got about 3 grand to put in a system and want the loudest subs i can possibly get for a daily driver
does any one have any suggestions
Username: Livin_loud
MW2 Addict
Post Number: 3331
what vehicle will you be using?
Username: Rovin
1 15 = 153 DBs ...Trinidad & T...
Post Number: 16826
does that 3k include electrical upgrades ? ...
Diamond Member
Www.stainles... .ecrater.com
Post Number: 24109
Are you starting from scratch or are we talking upgrade from an existing system?
Username: Skdooley
Roanoke, VA Usa
Post Number: 1394
You could have a great, solid daily system for 3 grand. Just don't focus all the money on just the subs and sub amp. Spread it across the whole install for a better all around system.
Username: Mmaudioconcepts
KY USA
Post Number: 720
start with a good headunit. a good signal to start from will work wonders and make the rest easier.
Username: Insearchofbass
Post Number: 16320
all good questions and suggestions
Username: Makinblak
Monroe/Monticello, La/Ar
Post Number: 268
Get everything used from a reputable site. Sundown amp fashizzle. x2 on the good head unit. maybe a pioneer premeir. Also, when you say "loudest" you just want a killer loud everyday SQ setup? Or will you competing for some high-pitch bass?
