1994 chevy ext cab
Username: Oneks707
Does anyone have blue prints on how to make a box that will hold
4- 12" subs for a 1994 Chevy Ext cab? A 7" monting depth will be big enough,
Thanks
oneks707@yahoo,com
Username: Glasswolf
Post Number: 13940
prints? no. That's the sort of thing I typically fabricate on the spot. You just pull the rear seating out and go from there. Take measurements, figure out what type of box (sealed or ported) you want, the space needed based on teh subs you chose, and calculate volume, then build the box, reinforce it, cover it, etc.
Username: Oneks707
Which way do you think will give me the best bass in a sealed box?
Having the subs face down or foward?
Username: Gcs8
Atlanta, Ga
Post Number: 1490
i have pretty good luck with sub up.
Username: Insearchofbass
2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ
Post Number: 15570
yeah go subs up
Username: Canaanwhite
Monroe, Louisiana USA
Post Number: 40
I use to drive a Blue Extended cab chevy truck and if put together right...they can get very loud.....
Username: Southernrebel
Post Number: 8343
WTF????
Have I met you at a USACi show? I sold that truck.
Username: Nd4spd18
Philadelphia, PA
Post Number: 11509
I drive a blue ext cab chevy truck
Post Number: 45
a common color in chevy trucks when it comes to car audio...lol
Post Number: 8345
Wait.
MS....i built a box for you once. Now you drive a blue chevy like I used to?
Ok, MS is the troll....riddle solved.
MS, in the blue chevy, w/ the soldering iron.
I win!
Post Number: 49
I'm glad we finally figured this out....I need another beer
Username: Nd4spd18
Philadelphia, PA
Post Number: 11510
lol canaan. I still have the black blazer you built me the box for. I also have a blue chevy truck now.
Post Number: 130
nice rides
Post Number: 15858
good guy too
Post Number: 262
he seems like it
