Need Opinions Please!!
Username: Jack_b
Hi, I've been browsing around a few companies looking at 15" subs and the amp/amps to power them and would really like some help from anyone with a bit of experience...
The subs...
RMS range of 500 upwards,
DVC; 2 or 4 ohms,
12" or 15"
Price range each from $50 - $120 (looking at buying from amazon/eBay or similar)
The amp/s...
Obviously just needing to match the specifications of the subs, preferably a little bit higher RMS, one or two depending on difference in price, suitability and quality.
Looking to spend $100 - $300 for one amp, or if two are need then $300 should be the max total price.
Just looking for some suggestions!!!
Thanks!
Jack
Username: Rovin
1 15 = 153 DBs ...Trinidad & T...
Post Number: 16748
http://www.audioque.com/aq/?page_id=72
Username: Jbpitt
Pittsburgh, Pa. Usa
Post Number: 848
x2 For both sub an amp.
Username: Mystre
Pemberville, Ohio USA
Post Number: 555
^ X2 or 3
Username: Glasswolf
Post Number: 13974
Alpine type R sub, and Audioque AQ1200D amplifier
Username: Canaanwhite
Monroe, Louisiana USA
Post Number: 105
Hi Jack you should check out the DD1515's....they are really nice 15's for the money...and American made...AQ uses Chinese made crap on all their lower end
Username: Nevertoomuchbass
Virginia Beach, VA
Post Number: 111
that dd1515 better sound like jesus for that price. you obviously didnt notice his price range
Username: Cenus
Post Number: 187
my re12.1 amp (200 plus sh) and two t3 t600 or t400's off ebay lol.
Post Number: 200
if you can find onew check in on the Audiobahn Immortals they were the best sub ever made but they are very rare and hard to find.....I hope this helps....
Username: Insearchofbass
2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ
Post Number: 15844
full of bad advise i see
Post Number: 247
opinions from someone who has never ran the Audiobahn Immortals I see
2 Fi Q 12s, Mmats 3000.1
Post Number: 197
opinions from someone whos never run any higher quality than audiobahn i see
Post Number: 15942
Your wrong i have run them
Post Number: 203
ill give you the fact that they sound half decent for the price though.
Post Number: 205
better sound for $200 than a kicker CVR.
Username: Makinblak
Monroe/Monticello, La/Ar
Post Number: 150
Back to the thread at hand.
Go to
http://www.caraudioclassifieds.org/forum/showthread.php?t=58975
and find you either some sundown, DD, L7, Solo-X, or Fi Q that fit your budget.
For the amp, you can get good price new at audioque.com or at above mentioned site. just match up your vc to your ohm output
Username: Jack_b
caraudioclassifieds website seems to be down at the moment for me :/
thanks though! ill try again in a bit..
Post Number: 15985
its a good place to get deals
