Picking up the sub today hopefully, tell me what you guys think.
Username: Stubbs563
Cedar Rapids, Iowa
Post Number: 191
I would like your opinion on the new settup options. I have found a DC Level 4 to run on my saz-1500 at ~32hz 4.5cuft, any pros/cons you guy can see in this right away. I am probably getting anoying asking all these questions about different woofers, so sorry -_-.
Thanks in advance!
Username: Tejcurrent
Post Number: 2539
Go for it if it's a 15
Username: Stubbs563
Cedar Rapids, Iowa
Post Number: 192
Theres an xl and a regular level 4 for around the same price, The only difference is d1 and d2, would running my saz at .5ohm be bad for my amp/car if i am running it on a 98 passat stock electrical with a redtop in the front.
Post Number: 2542
Probably. I'd get the D2
Username: Stubbs563
Cedar Rapids, Iowa
Post Number: 193
Cool, thanks troy, will have install pics after it arrives.
Username: Insearchofbass
2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ
Post Number: 15609
hopefully its the xl that was the right ohms if so youll like it alot
Username: Stubbs563
Cedar Rapids, Iowa
Post Number: 194
sean it is not its the D1, im not really sure the difference in the 4 or the xl but ive heard both will sound great off the saz
Post Number: 15632
Youll still like the lvl 4 but the xl has more umpth in the bottom end
My brothers sponsored by dc sounds so I get to learn alot about those subs.
Username: Stubbs563
Cedar Rapids, Iowa
Post Number: 195
So, if my shits tuned at around 32 or lower i would want the xl? eh eh eh? also do you happen to knw anything about the xl spl sean?
Username: Stubbs563
Cedar Rapids, Iowa
Post Number: 196
also what do the level 4s sell for new, and the xls?
Username: Talon01
Team dc audio, Pa Usa
Post Number: 2185
hello i am seans bro for that size box you can do 15 or 2-12's. i would do lv 4 with your power application.
Username: Talon01
Post Number: 2186
email me if ya want pricing nolan
Username: Stubbs563
Cedar Rapids, Iowa
Post Number: 199
What is your email?
Username: Talon01
Post Number: 2187
mamula1@comcast.net
Username: Canaanwhite
Monroe, Louisiana USA
Post Number: 152
Hows it sound ?
Post Number: 15853
did you get a dc sub
