Opinions on my setup,,,
Username: Nissankicker
Grambling, LA USA
Post Number: 308
As of tomorrow ( Oct. 20,2010 ), I'm putting:
6 12" Hifonics HFD4s
1 Autotek AT-2000.1
Custom Ported Enclosure
... In my 1999 Nissan Sentra GXE ( 4-dr )
My question(s):
1) How do you think it will sound...
2) Do you think it's " overkill "....
3) Etc.....
I will be posting videos and pictures of the entire build & all items...
... I'm just lookin' for advice ( good & bad ), suggestions, etc...
THANK YOU!
Username: Gcs8
Atlanta, Ga
Post Number: 1505
not fond of Hifonics, never heard of Autotek, do you have the power to backup that 2k amp if it does put out rated power. what electrical upgrades do you have? have you done your big 3? got a high output alt? nice battery? 1/0 ga wiring?
Grambling, LA USA
Post Number: 309
I have Big 3 Installed ( 2 runs of 4ga each )... Stock Alt... ( never had any voltage problems... )... Extra Battery ( Of course! ) - 2 Runs of 4ga wire from Front 2 Back - including Ground ( 0/1 is VERY high in this area - $6 per ft. )
Username: Gcs8
Atlanta, Ga
Post Number: 1507
http://www.knukonceptz.com/productDetail.cfm?prodID=KCA0BK-50
Username: Gcs8
Atlanta, Ga
Post Number: 1508
if if you want copper instead of cca. http://www.knukonceptz.com/productDetail.cfm?prodID=KFX0BK-50
Grambling, LA USA
Post Number: 311
Thanks for the info...
... NOW BACK TO THE TOPIC ON-HAND!
Advice, Suggestions, etc....
Username: Gcs8
Atlanta, Ga
Post Number: 1509
yes you will have a FUCKTON of cone area but you may do better with 2 larger drivers on the same power. i would also suggest a sundown amp or a audioque amp. those subs probably wont sound that great even tho there cheep ans its easy to just add cone are. however i would love to see this build and what it puts up on a TL. do you have a front stage that will keep up with sub stage?
whats your final ohm load going to be?
Username: Rovin
1 15 = 153 DBs ...Trinidad & T...
Post Number: 16741
deathoob never hear of autotek = deathnoob
j\p lol
autotek was very good a few yrs ago but now the quality has dropped
hifonics isnt the choice of most of us on E ...
Username: Gcs8
Atlanta, Ga
Post Number: 1512
i would like to see clamped power on that amp, my amp did ~2200 apparently when i when't to the last show, not bad for 2 ohms.
also hush rovin, only been in car audio for ~3-4 years now and only a year or so not failing at it.
Username: Insearchofbass
2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ
Post Number: 15633
x2
Grambling, LA USA
Post Number: 312
Yes... Right now I have JVC HXs 6.5s Coaxials in the Front stage w/ 6 tweeters accompanying them. - Mid Stage: Interfire Slims 6.5s w/ 1 tweeter each side accompanying them. - Rear Stage: Kicker KX 6.5s.
.... When I figure out what highs amp I wanna use PERMENANTELY I'm gonna install my Component sets ( 5 sets - 1 in each doors - 1 in the rear dash ) Total of 16 speakers & 18 Tweeters )
... But musical wise: It's CRYSTAL clear with the interior speakers I have now on a " Death Wish 360 " ( Old School Amp for the record )...
... I will be posting Pictures and a couple Videos of EVERYTHING - The 6 12s, the Autotek 2000.1, and the enclosure build.
Username: Gcs8
Atlanta, Ga
Post Number: 1513
how about this as a mids and highs amp?
Information on the new SAX-200.4 can be seen hear
Official Ratings off SAX-200.4 :
200x4 at 4 ohms
300x4 at 2 ohms
400x4 at 1 ohm
600x2 at 4 ohms
800x2 at 2 ohms
Actual tested - factory supplied figures :
210x4 at 4 ohms
350x4 at 2 ohms
465x4 at 1 ohm
665x2 at 4 ohms
925x2 at 2 ohms
Grambling, LA USA
Post Number: 313
That's d*mn good...
... Will keep that in mind ( definitely! )
Username: Glasswolf
Post Number: 13967
Personal opinion?
it's overly complicated.
Username: Loc_out
SoCal
Post Number: 3253
You might want to upgrade to 0/1. This way you can add more power to them sub's.
Grambling, LA USA
Post Number: 314
@ Glasswolf... true... but i like complicated.
@ LowLife... Yeah, you are right... I'm gettin' to that as we speak ( type that is )
Username: Glasswolf
Post Number: 13975
I don't.
too many things to go wrong, too many issues with things like soundstage, imaging, beaming, signal path lengths, cancellation, etc.
Keep it simple and you won't have nearly the issues with getting a good sound system.
I guarantee you I could set up a better sounding system with one 3-way component set in front, one pair of midbass drivers in back, and two subs, all running active.
simple, clean.
Username: Gcs8
Atlanta, Ga
Post Number: 1517
want to play with my car glass?
Username: Glasswolf
Post Number: 13981
maybe ^^
