Ot: what do you think?
Username: Gcs8
Atlanta, Ga
Post Number: 1471
http://www.audiobahn.com/Audiobahn/index.php?option=com_content&view=article&id= 213&Itemid=505
looks like audiobahn is trying again, it looks ok on paper but how do you guys think it will hold up in the real world.
Username: Skdooley
Roanoke, VA Usa
Post Number: 1243
They still look cheap to me.
Username: Gcs8
Atlanta, Ga
Post Number: 1472
excluding looks then? i want to know what the fuse rating is to see if its even close to what it states, also want to see what it does before it clips and how accurate the clip light is.
Username: Stubbs563
Cedar Rapids, Iowa
Post Number: 186
I wonder if the flames help with performance, any input on that?
Username: Southernrebel
Post Number: 8307
Hey look....they have the exact same amps they had when went out of business. Guess they had plenty of stock leftover or they bought them back from the trans-shippers on ebay.
Username: Gcs8
Atlanta, Ga
Post Number: 1473
i would think the flames over the fan vents would screw up the air flow.
hey canaan, senths you run a shop any way we could talk you in to power testing some amps from time to time? i would like to see how a variety of amps holds up to what they say they do.
Username: Glasswolf
Post Number: 13910
still look as lousy as ever. I doubt they perform that well, and the fuse rating is pretty meaningless. They can slap any size fuse in one they want. What matters is the power supply. what FETs are they using in the output stage? What is the Toroid capacity, and what size capacitors, and what type ar they using?
Username: Nd4spd18
Philadelphia, PA
Post Number: 11459
yep, same old audioburn by the looks of it.
Username: Gcs8
Atlanta, Ga
Post Number: 1474
must have been my inner geek that just wanted the volt meeter and the clip light for when i go to spl shows.
Username: Jbpitt
Pittsburgh, Pa. Usa
Post Number: 832
"I wonder if the flames help with performance, any input on that?"
They do acually,every flame adds an extra 100watts.
Username: Glasswolf
Post Number: 13914
yeah, but that's 100 watts PMPO, not RMS.
Username: Dsmith07
NC Http://com4....
Post Number: 959
the flames are external heatsinks
Username: Insearchofbass
2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ
Post Number: 15571
they wont stay around
