Sub vs sub
Username: Basshead94
Centralia, Illinois United States
Post Number: 24
i went ahead and decided to go with digital desings and as i was lookin over them some one said i should try the 9900 series
are they louder then the 9500 series?
Username: Glasswolf
Post Number: 13882
are you a pro class SPL competitor in burping events?
the choice of sub is only a small portion of making a system as loud as possible. Most people for daily driving musical use can use nearly any sub or pair of subs to get a system well beyond the pain threshold.
Post Number: 25
im a bass head tht wants more and tht wants to be louder then n e one in town so i was just wantn some advice
Username: Insearchofbass
2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ
Post Number: 15472
Please type properly.
Username: Stubbs563
Cedar Rapids, Iowa
Post Number: 181
^ x2
Username: Southernrebel
Post Number: 8298
The old DD9900's were just DD9500's w/ composite cones.
They now consider the composite cone an optional upgrade for the 9500 series subs.
Now, DD has the 9500, 95Z and 99Z.
The Z subs have neo motors. The 99z is a 12 slug/lens, 95z is a 6 slug/lens.
Username: Skdooley
Roanoke, VA Usa
Post Number: 1230
Getting loud is going to be dependant on the enclosure and power you're running, which then is dependant on your electrical upgrades. All needs to be up to par together.
Username: Cenus
Post Number: 150
pointless to get the 99 unless your a hardcore competior and have unlimted power. your probally better off getting the 3500's two of them with a nice 2500-3000wrms amp and a GOOD box should be more than enough to meet your needs.
Post Number: 15576
x2
