Sub question
Username: Pbplayer05
Omaha/council bluffs, Iowa
Post Number: 868
well there was something in my trunk that ruffed the surround on the sub up is there a way to just replace the surround or do i need to get a whole re-cone on it everything works fine just cosmetically it got ruffed up
Username: Glasswolf
Post Number: 13877
you can re-surround a speaker, you just need to get the correct surround from the manufacturer.
Post Number: 869
thanks thats what i was thinking not sure if the manufacturer makes them any more its an rd audio alpha v2 15"
