Battery
Username: Mystre
Pemberville, Ohio USA
Post Number: 564
Okay guys, I may have to be invest in a new battery for my car. This will be used to power the car, 2006 Chevy Impala, and it will be used to power my audio. The audio is 2 12" SAs and 1 SAZ-2000D, I do not have any other amps, I just use the HU to power the front end. Here are some options I have collected. Other options, opinions VERY welcome. I need to stay around $250. Thanks.
XS D5100 $235 + shipping
http://mechman.com/store/product_info.php/cPath/1/products_id/32
DieHard Platinum P-5 $190 picked up
http://www.sears.com/shc/s/p_10153_12605_02850035000P?prdNo=61&blockNo=61&blockT ype=L61
Kinetik HC 1800 $200 shipped
http://www.sonicelectronix.com/item_7342_Kinetik+HC+1800+-KHC1800%2C+HC1800%2C+K HC+1800-.html
Kinetik HC 2000 $230 shipped
http://www.sonicelectronix.com/item_7343_Kinetik+HC+2000+-KHC2000%2C+HC2000%2C+K HC+2000-.html
Username: Gcs8
Atlanta, Ga
Post Number: 1539
http://www.amazon.com/Shuriken-SK-BT120-120ah-Battery/dp/B0024ONDAY
Username: Mystre
Post Number: 565
I forgot to add that I will not be running the amp at full power constantly, only for demos. Probably will have it at about 1500 to 1800
Username: Mystre
Post Number: 566
death, is that good for cranking and audio?
Username: Mystre
Post Number: 567
Another thing death, that is way out of my price range. Any other suggestions?
Username: Mystre
Post Number: 568
How about this one?: http://www.sonicelectronix.com/item_17905_SHURiKEN+SK-BT100.html
Username: Gcs8
Atlanta, Ga
Post Number: 1540
I think there made in the same build house as xs. And any thing In that line shuld be good, wait for troy or glass to chime in. Its the company I plain on going with tho.
Username: Nd4spd18
Philadelphia, PA
Post Number: 11495
Diehard platinum ftw.
Username: Rovin
1 15 = 153 DBs ...Trinidad & T...
Post Number: 16764
been seeing these in some installs online : ...
http://www.dekabatteries.com/
Username: Loc_out
SoCal
Post Number: 3258
what about C&D tech?
Username: Mystre
Post Number: 571
What about this one?: http://toledo.craigslist.org/ele/2028055543.html
Username: Jbpitt
Pittsburgh, Pa. Usa
Post Number: 867
I think $190 for the diehard seems like the way to go.
Username: Mystre
Post Number: 572
The only thing about the Diehard is the CCA are alot lower than the others. Opinions?
Username: Kickerman
Post Number: 276
xs power d3400. should be factory direct replacement
or the s3400 with Steel Protective Case supposed to be better under the hood battery
Username: Mystre
Post Number: 575
Well, I just went and got the Platinum Diehard. I will let y'all know how it works.
