Single 8"
Username: Skdooley
Roanoke, VA Usa
Post Number: 1200
Not expecting miracles from a single 8, but if you guys had to choose, which sub would perform best: SA-8, RL-i8, or a DD 1508? No one has bought the 500/1 so I'll be running 500 rms one of these drivers.
Diamond Member
Www.stainles... .ecrater.com
Post Number: 23460
I'd go with the RL but most here would say the DD.
Username: Gcs8
Atlanta, Ga
Post Number: 1315
i would want to try the sa-8, have heard good things about it. but if you want a higher quality driver the RL or DD.
Username: Southernrebel
Post Number: 8243
I'm a little bias, but I have seen and built some sick setups w/ the DD1508's. So my vote goes to DD1508d4 w/ your amp. (they are available in D2 now also)
I like to match them up w/ the DD C2b (500w+) @ 2ohm. They are pretty picky when it comes to box design and loading though.
Username: Skdooley
Roanoke, VA Usa
Post Number: 1201
What would you say is an idle enclosure for a DD1508 would be Canaan?
Username: Insearchofbass
2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ
Post Number: 15247
go for quality do the rli 8
Username: Rovin
1 15 = 153 DBs ...Trinidad & T...
Post Number: 16668
never heard any of them but if i had to pick it wud be along the lines of sq like sean said : SS ...
Post Number: 8245
Enclosure will be totally dependent on vehicle.
Username: Skdooley
Roanoke, VA Usa
Post Number: 1202
The enclosure I had in there was tuned at 32 Hz and it peaked in my car at 45 Hz if that tells you anything.
Username: Dsmith07
NC Http://com4....
Post Number: 953
sundown 8's , they are supposed to be pretty cheap to recone.
Username: Skdooley
Roanoke, VA Usa
Post Number: 1203
Does AQ make an 8" sub? I saw a video of an 8" sdc, yet can't find one on their site. Anyone know anything about that sub?
Post Number: 15249
pretty sure that was a proto type....get the dd if you go that way they arent expensive from what i remember
Post Number: 8248
AQ did offer an 8" for awhile...it was the old SD series, back when they offered 3 lines
(SD, SD2.5, HD3)
They dropped the US-made subs and have all motors built in China now.
Thus the "C" in their current lines.
Username: Gcs8
Atlanta, Ga
Post Number: 1325
boo China.
Username: Deadrabit
Marionville, MO
Post Number: 2544
hey... i like china
Username: Rovin
Post Number: 16672
nothing is wrong with china in fact ALOT of stuff comes from there because of cheap labor - i bet even if u check ur underwear u will see made in china ...lol
alot of parts from the top audio brands r made in china just designed & hand assembled in the usa ...
Username: Skdooley
Roanoke, VA Usa
Post Number: 1204
Hey Canaan, what do DD 1508s with a carbon fiber dust cap retail for? How much do you think they're worth used in good condition?
