Gold Member Username: SkdooleyRoanoke, VA Usa Post Number: 1209 Registered: Oct-09 | I've found a guy selling a used Rl-I10 for $150. My first question is, is that a good deal? The sub is in good shape. Also, how would this sub compare to say a 10w6 or an IDQ 10? Not as good, same, or better? Planning on running sealed on 500 rms at 2 ohm (dual 4 ohm). Depending on what you guys have to say I might buy it tomorrow. For cheaper brand new I know I could pick up a SSA Dcon. What do you think I should get? I'm going for SQ. |
Platinum Member Username: Nd4spd18Philadelphia, PA Post Number: 11363 Registered: Jul-06 | http://www.sonicelectronix.com/item_11725_Eclipse+SW6010.html I say that b/c i run two of those and $99 shipped is a very good deal. But all of the subs you are looking at are good quality. |
Silver Member Username: PerfectcircleNaptown, Indy Post Number: 156 Registered: Feb-10 | if you decide you don't want it let me know how i might be able to buy it. always wanted to try one. |
Platinum Member Username: Insearchofbass2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ Post Number: 15265 Registered: Jun-04 | a new rli is 215 plus shipping |
