Username: Dubk777 Post Number: 1 Registered: Sep-10
Friday, September 03, 2010 - 19:00 GMT Wanted to know if a phoenix gold zx 500 would power an L5. Suggestions of other amps welcome
Username: Jbpitt Pittsburgh,
Pa.
Usa
Post Number: 763 Registered: Jul-09
Friday, September 03, 2010 - 19:55 GMT Is the sub dual 2ohm?
Username: Nd4spd18 Philadelphia,
PA
Post Number: 11338 Registered: Jul-06
Friday, September 03, 2010 - 21:13 GMT more importantly, have you bought the sub yet? If not don't.
Username: Skdooley Roanoke,
VA
Usa
Post Number: 1163 Registered: Oct-09
Friday, September 03, 2010 - 21:53 GMT The ohm load as asked is going to determine what amp you'll need. I wouldn't recommend the phoenix amp though.
Username: Dubk777 Post Number: 2 Registered: Sep-10
Friday, September 03, 2010 - 22:59 GMT Why should I not buy L5?
Username: Dubk777 Post Number: 3 Registered: Sep-10
Friday, September 03, 2010 - 23:03 GMT Yes it is 2 ohm if not phoenix gold what should I use
PA
Post Number: 11340 Registered: Jul-06
Saturday, September 04, 2010 - 02:09 GMT Because that is one of the worst mainstream subs out there, poor build quality and sounds like crap. Ask ppl on here for suggestions in your price range, you will get much better options than
