Bronze Member Username: JuggernutsPost Number: 17 Registered: Aug-06 | Hey guys, after tons of debating and hours of research, I bought my first pair of PG subs (RSDC124's) due to the outstanding reputation and reviews the RSD and RSDc's have gotten. Now my only trouble is trying to find an amp to power them with. I'm a little rusty on ohms and impedance, so i'm trying to decide what kind of amp I should get...ex-monoblock, class d, etc. They will be in a sealed box in the back of my dodge quad cab, and i'm guessing I need to run them at 1 ohm? If you could please help me with some suggestions on what amps to look at and what ohmage (is that a word? if it's not im making it one), it would be GREATLY appreciated. My budget range for an amp is up to $200. Thanks in advance for the help... |
Gold Member Username: Gcs8Atlanta, Ga Post Number: 1267 Registered: Sep-09 | http://images.the12volt.com/12voltimages/2_4ohm_dvc_1ohm.gif AQ1200D $249 each shipped http://www.audioque.com/aq/?page_id=72 spend the extra 50 you wont regret it. |
Bronze Member Username: JuggernutsPost Number: 18 Registered: Aug-06 | I'll definitely be considering that amp. Here are some other ones i've found, would they work? (need them to be ran at 1 ohm and 1000-1200 watts) Just wondering if they will push out close to their stated wattage for 1 ohm, and if you've had any reviews or experience with these. thanks! http://www.sonicelectronix.com/item_...PV2000.1-.html http://www.sonicelectronix.com/item_...VN1-2000D.html http://www.sonicelectronix.com/item_...o+TQ1601D.html |
Bronze Member Username: JuggernutsPost Number: 19 Registered: Aug-06 | Also, Should I look into getting a capacitor? Didn't know if I would need one for a 1200 watt amp.. |
Platinum Member Username: Nd4spd18Philadelphia, PA Post Number: 11329 Registered: Jul-06 | Your links dont work, but I second the AQ 1200d And no capacitors. Ever. |
Gold Member Username: Gcs8Atlanta, Ga Post Number: 1268 Registered: Sep-09 | my links work fine. |
Gold Member Username: Gcs8Atlanta, Ga Post Number: 1269 Registered: Sep-09 | oh u ment his my bad / ignore me. |
Silver Member Username: JbpittPittsburgh, Pa. Usa Post Number: 749 Registered: Jul-09 | No on the crunch an power acoustic,couldnt get the other link to work. I know its alittle more than you want to spend,but id definatly go with the aq1200d over those. |
Gold Member Username: Extrmndor3Http://illuzonemu.serv..., ^^^Sick Game Post Number: 8176 Registered: Feb-06 | dude im so fu-cking beutiful that my face hurts |
Platinum Member Username: Nd4spd18Philadelphia, PA Post Number: 11333 Registered: Jul-06 | sure its not from all the d|cks youve been sucking? KEEKER |
Gold Member Username: Extrmndor3Http://illuzonemu.serv..., ^^^Sick Game Post Number: 8177 Registered: Feb-06 | hahah look at the liviing piece of talking fetus we have now here.... hahahha yeah whatever my friend.. your the queen.... now get on your lil shitty azz blazer and go drive downtown... you poor poor thing i bet it feels bad bein you... dont worry give me your email ill paypal you a dollar.. FYI im in mexico lil f@g no necesito ablar ingles pinche puto cara de mi pito.. pikate el culito pinche jotito pendejo das asco puto vete a banar.. |
Platinum Member Username: Insearchofbass2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ Post Number: 15202 Registered: Jun-04 | yeah go with the audioque dont buy those other amps they are junk |
Platinum Member Username: Nd4spd18Philadelphia, PA Post Number: 11334 Registered: Jul-06 | |
Gold Member Username: Extrmndor3Http://illuzonemu.serv..., ^^^Sick Game Post Number: 8178 Registered: Feb-06 | fail? wait fail douchbag?? actually you the one who failed with your stupidity....... you telling me that because you in America and im in mexico i need to talk English.. yeah right go talk to your mom instead.. also are you really desperate of attention?? did you got your welfare check?? or thats the reason your mad?' |
Gold Member Username: DuckaShelby Twp., MI United States Post Number: 1498 Registered: Jan-08 |
I dont need to speak english, (something about facefucking his dick?) (something about disgusting azzhole take a bath?) meh 3 spanish classes... and they didnt teach slang.... or cursewords lol. |
