Like
Good amp for sub?
Username: Duckhunter92
Will a Kicker ZX750.1 push my jl 10w3(4ohms) good? If not, then any suggestion,
Username: Jbpitt
Pittsburgh, Pa. Usa
Post Number: 735
Yes it will
Username: Csaapproved
Holy crap, yes. Don't turn it up too loud, I think you have enough power to damage your sub if you push it. If you're good to it, it'll work great!
So would you suggest i go with something smaller?
Username: Jbpitt
Pittsburgh, Pa. Usa
Post Number: 742
^I wouldnt. Your sub is single 4 ohm right? So you only need an amp that does 300wrms @ 4ohm. That kicker amp does 375wrms @ 4ohm. So... you would be fine running the kicker amp.
This is a good amp that would work for you too.
http://www.sonicelectronix.com/item_12018_Alpine+MRP-M500.html
Facebook
Shop Related Deals
Directory
