Username: Glock40 Post Number: 44 Registered: Jul-09
Saturday, July 24, 2010 - 03:01 GMT I have a pretty large box, but i was wondering if you can get carpet for them bigger than 4'?? Or will i just need a couple and tie them in? I know how to but wondering if you can buy a bigger piece.
Diamond Member
Username: Wingmanalive Www.stainles...
.ecrater.com
Post Number: 23195 Registered: Jun-06
Saturday, July 24, 2010 - 03:08 GMT Go to a fabric store. They sell by the yard with possible selections you could use.
Username: Southernrebel Monroe,
Louisiana
Team Audible...
Post Number: 8179 Registered: Mar-04
Saturday, July 24, 2010 - 03:55 GMT Most fabric/boxcarpet comes in 48", 52" or even 64" wide. I usually order 48inch wide x 100 foot carpet for the shop. I seam the carpet in a reasonably unnoticeable area. For instance the bottom of the box. Or I create a VERY NOTICEABLE seam, say at the area in the box where I have a designed 2-tone design.
Username: Dustin3 Box Designer & Builder...Dustin
Post Number: 5712 Registered: Oct-05
Saturday, July 24, 2010 - 07:52 GMT Like Canaan said, most carpets come in 52" and 64" wide pieces. So if you have a large box, just get 3-4 yards and your fine...
Username: Glock40 Post Number: 45 Registered: Jul-09
Saturday, July 24, 2010 - 21:07 GMT thankyou all, but where could i get like a 52" or 64" wide box carpet?? like at a car audio shop, or home depot?
Post Number: 5714 Registered: Oct-05
Saturday, July 24, 2010 - 22:15 GMT http://www.parts-express.com/wizards/searchResults.cfm?FTR=carpet&search_type=ma in&WebPage_ID=3&searchFilter=carpet&x=0&y=0
Username: Glock40 Post Number: 46 Registered: Jul-09
Saturday, July 24, 2010 - 22:27 GMT exactly what i need, thanks bro
