New member Username: Sloom08Somewere, Mississippi U.S. Post Number: 2 Registered: Jul-10 | I want a little help on upgrading my system, i was wondering if I should do 4 15" audioque sdc2.5 of 2 15" hdc3 subs on a audiopipe 3000.1? I have a dual 15" super pro bass box, and a ported box for 4 15s need a little help deciding which will be better! |
Silver Member Username: M_kimmel843Post Number: 169 Registered: Apr-10 | Well more cone area yields more output. I guess it just depends on how much room you want to take up in your vehicle because a box for 4 15's would have to be pretty substantial. Either way you go, I'd get rid of the boxes you have and have someone build you custom enclosures. I hear that Bassman3 on this forum builds awesome enclosures and he is pretty reasonable on his pricing. |
New member Username: Sloom08Somewere, Mississippi U.S. Post Number: 3 Registered: Jul-10 | Matt have u heard of the pro boxs |
Silver Member Username: M_kimmel843Post Number: 170 Registered: Apr-10 | Yes, I have. I owned one about 4 or so years ago! It was a decent box, I'm not going to lie. I'm just saying that if you can, have someone build you a nice custom enclosure. Pro boxes are alright but they are still not the same as a nice enclosure built to maximize the output of which ever woofer or woofers you choose. I wasn't trying to say they were bad, rather trying to give you more options for even more output. |
Silver Member Username: Boston_splHighland, CA United States Post Number: 288 Registered: Nov-08 | ^x2 |
Silver Member Username: MystrePemberville, Ohio USA Post Number: 241 Registered: Sep-05 | ^x3 |
Silver Member Username: RosrockMichigan Post Number: 489 Registered: Mar-09 | ^x4 |
New member Username: Sloom08Somewere, Mississippi U.S. Post Number: 4 Registered: Jul-10 | http://www.cardomain.com/ride/3090 Check out this link 2 see my ride And now that I think about it I think im goin 2 go for 4 sdc2.5 12s because the 4 15s dont leave any room 4 batteries and without them I wont b hittin anyway what do u all think? |
Silver Member Username: Gcs8Atlanta, Ga Post Number: 881 Registered: Sep-09 | spend a lot of money at best buy? |
Gold Member Username: SomedonniedudeIllinois Braaap MX Post Number: 3061 Registered: May-07 | "And now that I think about it I think im goin 2 go for 4 sdc2.5 12s because the 4 15s dont leave any room 4 batteries and without them I wont b hittin anyway what do u all think?" Yes you will need batteries, because without them your amp will fry. Honestly thought, unless you are competing and/or need a big battery power reserve for when your vehicle is off, just get a good High Output Alternator and the biggest/best battery you can fit under your hood. You may not even need extra batteries in the back this way you can fit your 4 15"s |
New member Username: Sloom08Somewere, Mississippi U.S. Post Number: 5 Registered: Jul-10 | @ some donnie dude-Wat do u think of my current setup |
Gold Member Username: DuckaShelby Twp., MI United States Post Number: 1463 Registered: Jan-08 | I like the way you have those capacitors sitting on your backseat. |
Gold Member Username: DuckaShelby Twp., MI United States Post Number: 1464 Registered: Jan-08 | Just realized they are on the floor and the seat is out. My bad. |
Silver Member Username: Boston_splHighland, CA United States Post Number: 294 Registered: Nov-08 | "Wat do u think of my current setup" With all due respect... you don't want us to answer that question. Trust me on this. |
Gold Member Username: DeadrabitMarionville, MO Post Number: 2467 Registered: Jun-07 | y not get 2 18 HDC3? if not go with the 4 15s |
Silver Member Username: CwruckPost Number: 375 Registered: Feb-10 | i say get a different amp and go for 4 sdc 12's or 15s. a 300 amp alt would almost power your current amp, you may even need a batt to help with voltage drops when you crank the volume and really start pulling a ton of amps. nice ride, not gonna lie i would take it over mine! lol |
Gold Member Username: DeadrabitMarionville, MO Post Number: 2468 Registered: Jun-07 | i started out with 4 15s... a pair of 18s would be better for burps or spl. but 4 15s will "sound" louder because of cone area |
New member Username: Sloom08Somewere, Mississippi U.S. Post Number: 7 Registered: Jul-10 | @ Ducka thanks homie I gotta put up sum new pics tho cause it has all fosgate 0 ga wire and a batcap now but da caps r still n da same position @ €hritoheR i kno its not the best system n da world but its sumthing all done and funded by me a 19 yr old college student and wer im from my system is one of da loudest n town fi, audioque, dd, dc, ascendant are not known here all that is played is rockford, kicker, alpine, things of that nature. I kno its also not da best looking r sounding either because n my car i have 2 rockford p3 12s on a rockford t500-1 and it sounds better than da kickers constructive critism is always welcomed! @ every1 thanks 4 all of ur input and ideas 2 hdc3 15s should b plenty the pro box is 3.75f cu ft on each side tuned 2 36 hz so i think it should do me just fine im not goin 2 b competing r anything of that nature but it should b pretty loud i would lik 2 kno wer i can find a ho alt at a good price |
