New member Username: ThemonsterPost Number: 1 Registered: Jul-10 | i dont know anything about car audio or what brands are good and i dont want to get bad sound subs. im looking for subs with excellent sound quality, and about an equal mixture of bass and highs. right now i have 0 in my account but soon im going to start saving for a system in my f150. any recommendations on what i should look for or into? |
Silver Member Username: JemoneTucker, Georgia United States Post Number: 375 Registered: Jan-06 | Welcome to eCoustics. The guys here will give you good advice on fantastic products. We all have one shortcoming though, we do not have your ears. Simply put ,you need to go out and listen to a few products and see what sounds good to YOU. The folks here will soon weigh in and make amicable suggestions. Good luck on your search dude. |
Silver Member Username: CwruckPost Number: 373 Registered: Feb-10 | what would be a realistic price range? to get great sound is going to cost more than $200 and if you have nothing saved up it could take you longer than you think to build your system up. i would guess most people spend months getting their system the way they want it too, but its worth it in the end |
Silver Member Username: Gcs8Atlanta, Ga Post Number: 889 Registered: Sep-09 | 5 years and counting, hoping my new build will put me where i want to be. but yes give us a price range you are willing to spend. |
Silver Member Username: Gcs8Atlanta, Ga Post Number: 890 Registered: Sep-09 | btw flat you only live 30 min away. |
New member Username: ThemonsterPost Number: 2 Registered: Jul-10 | im willing to drop about 1500 on the amps kickers, and subs. but im still 17 and soon when i get a job ill get it pretty quick cuz i still live with my parents and ill have some side jobs too |
Silver Member Username: Gcs8Atlanta, Ga Post Number: 892 Registered: Sep-09 | kickers? as in the brand? theres better amps. get a nice saz-1000D a SA - 12, nice head unit, some good 1/0ga wire, knu or shok, good set of rca's, a sax - 125.2, poke around for a set of components you like the sound of, that should get you started. http://www.soundsolutionsaudio.com/store/products/Sundown-Audio-SA%252d12.html http://www.soundsolutionsaudio.com/store/products/Sundown-Audio-SAX%252d125.2.ht ml http://www.knukonceptz.com/productDetail.cfm?prodID=KFX-PK20 http://www.soundsolutionsaudio.com/store/products/Sundown-Audio-SAZ%252d1000D.ht ml |
New member Username: ThemonsterPost Number: 3 Registered: Jul-10 | yea, thanks. i was at new era but i didnt know anything about speakers or anything but i liked the Vega Mobile 10" subs. they sounded clean, not too much bass or too much highs. cuz i want to see what everyones opinion is for speakers so im lookin garound to see. |
Silver Member Username: CwruckPost Number: 376 Registered: Feb-10 | what type of vehicle do you have? that can help with the size of the sub, but i say a 15" ssa xcon or 15" fi q for great sound, or you could go smaller as well, maybe run some 12's or 10's sundown amps are very nice and one of the best you can buy right now could easily get the subs and amp taken care of for 600 or so. you have any experience with building boxes? the box is probably the most overlooked thing in car audio. new people will just get the cheapest box possible and wonder why it doesnt sound that great. you really need to look into getting a custom box built if your going for aported set up |
New member Username: ThemonsterPost Number: 4 Registered: Jul-10 | i have a 98 f150 xlt. its a 3 door and the seats in the back are close to the ground. |
Silver Member Username: RosrockMichigan Post Number: 490 Registered: Mar-09 | if ur on a budget may wanna buy a used amplifier off craigslist or ebay. do u know roughly how much continuous/rms power you wanna run? what kinda alt and bat ya got? |
Silver Member Username: Gcs8Atlanta, Ga Post Number: 898 Registered: Sep-09 | or http://www.caraudioclassifieds.org/forum/forumdisplay.php?f=71 |
Silver Member Username: Boston_splHighland, CA United States Post Number: 296 Registered: Nov-08 | Are all of the electrical components in your truck stock? |
