Speakers thump when doing ANYTHING
Username: Jmartin2323
Cleveland, Ohio United States
Post Number: 50
this isnt my car specifically but ive been asked to fix the prob. when he turns on the radio THUMP. turns off the radio THUMP. turns volume from 0 to 1 THUMP. hes got a couple amps, decent install. pioneer HU. any suggestions on what this may be?
Username: M_kimmel843
Post Number: 141
Check the ground connections, sounds like you have a very bad ground loop.
Username: Insearchofbass
2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ
Post Number: 14544
x2
