OT-elemental designs edead 45?
Username: Sleste8
Shelbyville, MI United States
Post Number: 274
what do you guys have to say about this stuff? any one here have any experience with this stuff, good or bad?
because at $1 a square foot, i think im going to have to try it. i only want to do my front doors. so it probably doesn't have to be the best stuff. and i can double or triple layer if need be because it's just so cheap.
any and all input always welcome, tyvm.Upload
Username: Gcs8
Atlanta, Ga
Post Number: 719
i think bassman3 has played with edead or fatmat i cant remember, but i would say give it a shot cant be worse then dynomat.
Username: Sleste8
Post Number: 275
ok, thanks for the input man. i think i'll just order the 20 square feet than. just to see how it does. i just hope it sticks fairly well.
20 should cover the front doors on a cherokee sport 4 door? buy the way, what are you using for dampening on your project deathoob?
Username: Gcs8
Atlanta, Ga
Post Number: 720
second skin SPL tiles
Username: Sleste8
Post Number: 276
nice, did u get them B-stock?
Username: Gcs8
Atlanta, Ga
Post Number: 721
yah, they hold fine.
Username: Sleste8
Post Number: 283
well i just decided to go ahead and order 20 square feet for $20 shipping was 12 sumthin, but then i looked up a coupon code and got 4 off. so it was like $28.
i no it's not the best, but it should do ok for my front doors. ill do a couple layers seems how it's only 45mils thick. and i have small doors.
well see!! ill post pics of the install, and updates when it falls off, lol
but hopefully it doesn't
Username: Gcs8
Atlanta, Ga
Post Number: 727
jb weld
Username: Sleste8
Post Number: 287
that's a damn good idea! but do you really think it's guna be that crapy? i guess i just don't know what to expect...
Username: Gcs8
Atlanta, Ga
Post Number: 736
never know tell you try.
Username: Sleste8
Post Number: 307
well 20 square feet just came. i guess ill run a little test.
i cleaned the surface with rubbing alcohol, and applied the edead 45 with a wooden roller. it's about 83-85 degrees here right now. and the high says 89. i no it's nothing compared to the inside of a car but oh well.
http://i843.photobucket.com/albums/zz358/X_livinloud/DSC02567.jpg
http://i843.photobucket.com/albums/zz358/X_livinloud/DSC02569.jpg
we'll see what happens, (started at 12:00)
Username: Gcs8
Atlanta, Ga
Post Number: 787
it looks very white. lol.
and y does every 1 have a nicer work shop than me?
Username: Sleste8
Post Number: 308
well it's just over 90 now and it's still looking the same. no peeling or sliding.
and it's not quite white. but it's nothing like the foil-type backing found on almost every other deadener. it has like a plastic mylar backing. plenty of time left for testing before i decide to use tho. i did do a flick test. it's nothing like the ringing the raw metal made by it's self.
test piece was 4"x12" on a 14"x27" piece of cold rolled tin. what percent of coverage does that work out to be?
Username: Bonhamd
Traverse City, MI
Post Number: 2244
roughly 12.7% i believe
Username: Insearchofbass
2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ
Post Number: 14600
I think I have 240 feet of this stuff but have yet to use it
Username: Sleste8
Post Number: 318
it's still holding fine, and with all the heat and humidity too. seems to be fine to me, still hasn't slid or pealed yet.
Username: Mystre
Pemberville, Ohio USA
Post Number: 227
Looking good. Is that a can of Red Dog beer?
Username: Sleste8
Post Number: 320
haha, yeah it is. i found it when we moved here in september. ill get someone to drink it someday, lol
i plan on putting the edead in the front doors when i get back from vacation next week. im just guna do what you did eric, use coax's for now. and ill upgrade at another time.
Username: Mystre
Post Number: 228
Man, that would be nasty. Red Dog was nasty anyway. Turn the can upside down and look at the dog. It should look like Batman in between Catwoman's legs. LOL
Username: Jbpitt
Pittsburgh, Pa. Usa
Post Number: 520
^Nice lol. I drank that a time or 2 and never knew that.
Username: Mystre
Post Number: 230
Do you know what Budweiser and Adidas stand for?
Username: Jbpitt
Pittsburgh, Pa. Usa
Post Number: 523
I think i know adidas,not sure about the bud though.
Username: Mystre
Post Number: 231
OK. Adidas is All Day I Dream About Sx
Budweiser is:
Because
U
Deserve
What
Every
Indivual
Should
Enjoy
Regularly
Username: Jbpitt
Pittsburgh, Pa. Usa
Post Number: 526
Nice! Ok,thats what i thought. For adidas we also used 'all day i drink an smoke'
Post Number: 14622
but not anymore right
