whats the price on the sdc? and for the fi ssd, is there a big difference between porting it or sealed? because i'm not sure i have enough room for a ported enclosure
i have heard a few 12's before, not too bad for the money as far as in the same price and power handling range the only one that i see fitting there is the SDC2.5. the ssd is nice but $60 more and the stuff on ssa in the same price range does not have quite the same power handling
I figured that, they seemed too good to be true at first glance. What would you recommend then? I'm not getting them right now, so I have time to figure out whats perfect.
so again ill ask, ur looking for sql and have a budget of under 200 dollars? and ur gonna need a custom ported box if u wanna port, which will run u 120-150
ok, well the i reccomend you just get one 1000 rms 12" sub and port it, ficaraudio.com has an fi Q bnib shipped for 240, supreme SQ along with bOOm. I use to have the ssd, which is the line below that and i liked it.
How much rms are you looking to run? I ask this because if ur looking to run 1200+ then ur gonna wanna look into get a ho alternator which could run 200+ as well as a big 3 upgrade and a 2 gauge amp kit
I don't see your problem with me saying somewhere around there. It gives a nice play area. I'm not saying i want to spent strictly 120 each sub. I'm open to prices which should make it easier. and thank you m.s. I was wondering that
If you wanted a good amount of sound, you could run 2 10" Fi SSDs in a sealed enclosure. It'd fit into the trunk well and would do nicely on ~1000 rms.
Thank you, i'm leaning that way now. Do you think that would be better than say, one fi Q? My first system was two ten inch mtx 4500 so you can imagine i'm looking to upgrade lol
lol, yeah i bet. i had 2 mtx 9512's not too long ago. they were ok, but just didn't do the job. never go under the 8500's tho. there all terds after that..
