Username: Rosrock Michigan
Post Number: 215 Registered: Mar-09
Saturday, May 29, 2010 - 20:30 GMT should i tell my box maker to add a double front baffle since my tc9 weighs 30+ pounds and is taking 1200 rms. I hear it is reccomended. is it neccassary?
Username: Gcs8 Atlanta,
Ga
Post Number: 524 Registered: Sep-09
Saturday, May 29, 2010 - 20:38 GMT i think you are ok up to 1500 watts but i could be wrong wait for some one else to chime in.
Post Number: 216 Registered: Mar-09
Saturday, May 29, 2010 - 22:51 GMT thx death, bassman or glasswolf what yall think
Username: Dustin3 Box Designer & Builder...Dustin
Post Number: 5605 Registered: Oct-05
Saturday, May 29, 2010 - 23:39 GMT It's always a good idea to double baffle a 12" woofer (I always do) 10" your fine with a single usually.
Username: Tejcurrent Post Number: 2249 Registered: Apr-07
Sunday, May 30, 2010 - 02:50 GMT I'd double if there isn't much bracing
Post Number: 223 Registered: Mar-09
Sunday, May 30, 2010 - 02:57 GMT yea ok... cause its just .75 mdf wood ill let him know thx
Username: Glasswolf Post Number: 13725 Registered: Dec-03
Sunday, May 30, 2010 - 02:58 GMT I'd double it. helps support the heavy drivers, and adds some stiffness to the enclosure to help reduce resonance and coloration. can't hurt.
Diamond Member
Username: Wingmanalive Www.stainles...
.ecrater.com
Post Number: 22850 Registered: Jun-06
Sunday, May 30, 2010 - 05:06 GMT Not to mention a double baffle offers a recessed design possibility/option.
Username: Nyyfan13 Northern VA
Post Number: 11906 Registered: Jul-06
Sunday, May 30, 2010 - 05:28 GMT My thoughts exactly Paul. I think we both are big fans of the recessed look Do you have to double it? Nope. But there's no reason to not do it. It won't hurt anything and it can only help.
Username: Hdubb Team Revolution
Post Number: 4320 Registered: Nov-04
Sunday, May 30, 2010 - 15:09 GMT id double every side of the enclosure.you can never have too stiff of a box
Diamond Member
.ecrater.com
Post Number: 22853 Registered: Jun-06
Sunday, May 30, 2010 - 15:54 GMT quote: you can never have too stiff of a box
Oh reeeeeeaaaallllyyyyyyy??????????
Username: Joebruce TC Sounds/DLS
Post Number: 3019 Registered: May-04
Monday, May 31, 2010 - 03:41 GMT I like the recessed look but it is a b*tch to get the sub in/out. Well without smashing your fingers. Id suggest double front but skip the recess for the sub.
Diamond Member
.ecrater.com
Post Number: 22855 Registered: Jun-06
Monday, May 31, 2010 - 03:58 GMT Just how do you smash your fingers Twiz?
Post Number: 231 Registered: Mar-09
Monday, May 31, 2010 - 04:11 GMT lol
Post Number: 3022 Registered: May-04
Monday, May 31, 2010 - 04:23 GMT Maybe Im just an idiot but any time I take my sub out I have to use a flat head to pry it up then slide my fingers under it and then remove it. Thats the easy part. When Im trying to put it back and line it up with the screw holes it is a pain. When Im trying to line it back up thats when it'll catch my fingers lol. Ive probably had to start 2 or 3 different holes just cuz I couldnt get it lined back up the right way. Plus my sub weighs roughly 40-45lbs. But its not like Im removing my sub from the enclosure everyday or anything,Im jus sayin.
