Sub break-in tone sweep?
Username: Delsole
Post Number: 1553
Ok guys i just got my HDC3 15's in and i decided i would like to break them in before i put them in my car. I have them hooked up to my home audio receiver.
Now i have a tone generator and im just wondering what you guys think would be the best tone sweep to break the subs in.
Should i do 1hz-250hz should i do 20hz-80hz i mean the possibilities are endless. let me know what you guys think. I currently have it from 15-50 until im told otherwise, and i will continue to play it until my receiver gets to warm.
Username: Delsole
Post Number: 1557
bump for a good answer.
Username: Rovin
1 15 = 152.5 DBs ...Trinidad & T...
Post Number: 16325
where r the pix ?
this is what i do :
run a 20hz constant for a hr or 2 the 1st few days at about 1\4" excursion with low volume to loosen it up a bit , then as each day goes by i use a bit more vol & let it run for a bit longer with a little more excursion...by a wk they shud be loosen up fairly good enough
that is my personal method which ppl may or may not agree with but it works for me ....
Username: Delsole
Post Number: 1560
Dont worry there coming, it just sucks i have to shrink everything.
i had the sweeping last night for about 6 hours on and off from 15-30hz with about 3/16 excursion. I guess i will bump it up a notch today.
Username: Rovin
Post Number: 16327
not bad but lessen down on the time to about 2hrs max since u wont want those coils to heating up after 6hrs , if u want them to break in faster rather than 6hrs non stop : u cud probably run it at closer intervals meaning give them a hr or 2 to cool down then back it again
might be a easier for u to make a vid & put it on youtube instead ....
Username: Sleste8
Shelbyville, MI United States
Post Number: 168
ive always wondered what sweep to use when breaking in subs too. i guess everyone does it different though.
