Silver Member Username: Gcs8Atlanta, Ga Post Number: 511 Registered: Sep-09 | so i built a little 8" sub with a passive raidior. the PR dosent move the same as the main driver.... or is that suppose to be how it works? |
Gold Member Username: SouthernrebelMonroe, Louisiana Team Audible... Post Number: 8046 Registered: Mar-04 | The radiator should move reverse of the sub. |
Silver Member Username: Gcs8Atlanta, Ga Post Number: 514 Registered: Sep-09 | well its much more eratic then the main driver. |
Gold Member Username: SouthernrebelMonroe, Louisiana Team Audible... Post Number: 8047 Registered: Mar-04 | What sub, box volume and mass loading on the PR did you use? |
Silver Member Username: Gcs8Atlanta, Ga Post Number: 515 Registered: Sep-09 | http://www.parts-express.com/pe/showdetl.cfm?Partnumber=295-480 box is ~10"x~10"x~10" and it was moveing way to much so i put one of the sockets from my tool box on the weight screw as they did not send me weights with it so i impervised. |
