Insulation
Username: Arnotjie
Post Number: 26
Hi.
I was just wondering what you guys would recommend, to prevent some of the rattles in your car? I've been in a lot of cars where the rattle completely ruin the sound of the subs. So I was just wondering what you guys do, and how much it will cost (see if it fits into my budget).
thanks.
Username: Philly306
Sorry, I have a new 20...
Post Number: 1559
http://www.secondskinaudio.com/
sign up for their mailing list theres usually some really good deals on b stock items.
Username: Delsole
Post Number: 1530
I have had good luck with Fat Mat That i got off ebay. Its very reasonably priced and works well.
Honestly there are so many different kinds out there and for the most part they all work. Although some better then others its your choice to decide which one you want.
